Please clarify bumper hitch rating for me
jwichman
Reg. Dec 2003
Posted 2005-05-02 2:10 PM (#24584)
Subject: Please clarify bumper hitch rating for me
Someone please clarify bumper hitch ratings for me.
It was my understanding that they were classified as class I, II, III, or IV. Class III hitches were good for 500/5000lbs. Class IV was good for 750/7500lbs. A class IV hitch was class III hitch with a weight distributing add on.
Any of what I've said close? Am I now reading about a class V hitch on newer vehicles?
chadsalt
Posted 2005-05-03 6:01 PM (#24668 - in reply to #24584)
Subject: RE: Please clarify bumper hitch rating for me
1000100100100100
Originally written by jwichman on 2005-05-02 3:10 PM
so as not to be rude, someone should reply. guess ill take a shot.
basically that looks right, depends on who you ask.  as far WDH it is my understanding any trailer with a tongue weight over 500 should use one. of course most people dont, and they seem to do fine.  as for the class V, ive always heard/read/assumed it was 1000/10000 but if im not mistaken, ive also read something about the new superduty with the 2 1/2 inch reciever called a class V but it was rated to something like 12000.
dare i ask (so as not to start another 3 page thread) why you are curious?
jwichman
Reg. Dec 2003
Posted 2005-05-04 8:01 AM (#24695 - in reply to #24668)
Originally written by chadsalt on 2005-05-03 6:01
Recently upgraded from a old, small, 2 horse BP straight load to a newer much larger, heavier, slant load. Manufacturers lititure stated must use WD hitch with new trailer. Started looking at others with similar trailers and couldn't find any using WD hitches. Went to local DOT weigh scale and had trailer weighed empty, 480lbs/3400lbs with 500lbs/5000lbs trailer hitch. Add the weight of two horses and gear I think I will exceed hitch rating.
I can't belive that most of the similar trailers I see running down the road are not similar in weight. Thought maybe there was a heavier rated hitch out there that could handle more wieght. New hitch maybe cheaper than WD?
efaubert1
Posted 2005-05-04 12:01 PM (#24716 - in reply to #24584)
50010025
Ok, honestly the hitch manufacturers don't even come together on this very well. Hidden hitch has on chart, putnam has another, reese and titan have yet another set of numbers. In general a classIII is 500/5000 WC(weight carry) 750/7500WD(weight distributing), class IV is like 800/8000 WC and 1100/11000 WD, and a class V is 1000/10000 WC and 1500/15000 WD. These numbers are for 2" inch square tube receiver hitches. The 2.5" square tube super classV is like 1200/12000 WC and 1500/15000 WD according to what I read. Mind you, it also requires a ball with a shank bigger than the standard 1" threaded portion to attach to the ball mount. 1" shanked balls are all pretty much rated for a max weight of 6000 pounds max. To get beyond that you have to jump up in shank size or go with a machined, heat treated ball that could be rated with a 1" inch shank, for 12000 pounds, but then it's a 2" 5/16" ball, not 2" inch. Heres a link to help you out.
http://www.trailersnhitches.com/putnam/hitchacc/hitchballs/hitchballsmain.htm
Posted 2005-05-04 1:07 PM (#24718 - in reply to #24695)
Originally written by jwichman on 2005-05-04 9:01 PM
Don't know what vehicle you're pulling this new trailer with ... But for what's its worth ...
GM's trailering guide says all 1/2 & 3/4 ton P/U trucks REQUIRE a WD hitch for all bp trailers over 5,000 pounds.   It's in a footnote.  So how many people read footnotes ??  Much less tow with the proper equipment..
Flush
Posted 2005-05-04 1:46 PM (#24720 - in reply to #24584)
From what I have learned, the whole "class" ratings of hitches doesn't seem to mean too much.
Looking at Reese's website for an F250 for example, you can get 3 different hitches that are all called "class 3 + 4" and they have ratings of 5,000lbs, 6,000lbs, and 7,500lbs (all without weight distribution)
They also have a class v, that is rated up to 12,000lbs (without WD)
So, you may be able to get a new hitch that does not require a weight distribution unit. However like Hosspuller noted, some lighter duty trucks with softer rear springs etc. probably should use WD, even if the rating of the hitch doesn't require it.
Here is Reese's website http://www.reese-hitches.com/
 -Flush
P.S. After joing this board I have paid particular attention to every horse trailer I have seen, and I have YET to see a horse trailer with a WD setup, even though some are well over 5,000#. I'm not saying that this means its safe, just surprised more aren't using WD. I suppose it's because most of the serious horse pullers are just using a GN anyway.
chadsalt
Posted 2005-05-04 3:04 PM (#24722 - in reply to #24718)
1000100100100100
Originally written by hosspuller on 2005-05-04 1:07 PM
i enjoy footnotes..........good conversation starters.
chadsalt
Posted 2005-05-05 1:16 PM (#24761 - in reply to #24720)
1000100100100100
Originally written by Flush on 2005-05-04 1:46 PM
whats even more interesting/annoying is when i went to puchase my new BP and knowing i was going to use a WDH, i found quite a few trailers came standard with tongues to short to use a WDH. most WDH mounts are set a 32" from the ball, quite a few trailers only had 30" tongues some were as short as 24". ended up ordering mine.
gabz
Posted 2005-05-10 11:59 AM (#24937 - in reply to #24584)
1000100100100252525
I don't bother with the classifications because they do not seem to be consistent between truck or hitch manufacturers.
I did have a 2" bar hitch with a 2 5/16ths ball that had a rating of 6000 pounds weight carrying (without WDH) and 10k with WDH... odd, huh.
Exceeding the hitch rating is so common with bumper pulls - there's some old threads about it. It goes back to the truck salesperson who says - "oh sure" no problem. The truck can haul 8000 pounds!!"  but they don't understand about the additional HEIGHT of horse trailers or the movement of hauling live animals, or the rating on the hitch itself.
Or - trucks that can haul 9300 pounds but only have a 1750 payload allowance. It just doesn't add up. Or as chadsalt as found - tongues that are too short, or covered, which makes using a WDH a pain because now you have to have someone cut the steel covering the A frame to make openings for the WD arms.  Yup - that's what drove me to a gooseneck. The WDH and modifications would have been over $500; the gooseneck hitch was around $650.
chadsalt
Posted 2005-05-10 3:22 PM (#24948 - in reply to #24937)
1000100100100100
Originally written by gabz on 2005-05-10 12:59 PM
good point about the classifications. id have to disagree with the "only 1750" though, seems like i remeber when a 1/2 ton only hauled a 1/2 ton. 1750 is well into 3/4 ton, not bad progress from the automotive world IMHO. BTW if anyone was wondering (OP), it only took a few minutes, a jigsaw, and a couple large sockets to "intstall" my "equal-i-zer" brand WDH ($399 off the web, wont leave home without it). took a couple hours and a few test rides to get it "set up" perfect.
gabz
Posted 2005-05-10 5:39 PM (#24952 - in reply to #24948)
1000100100100252525
Originally written by chadsalt on 2005-05-10 3:22 PM
Well, the point I was trying to make was that if I can haul 9300 pounds - I personally would prefer to NOT put that on a "bumper" hitch (a 10 - 15% tongue weight); therefore, I need 1860 pounds for a 20% coupler weight allowance in payload - and that's with NO passengers or cargo in the truck...  but some GN/ 5th wheels require you figure 25% coupler weight as payload....  and that's why I said the numbers don't add up.
chadsalt
Posted 2005-05-10 8:53 PM (#24960 - in reply to #24952)
1000100100100100
Originally written by gabz on 2005-05-10 6:39 PM
yes i understand that, and youre right....i was just looking at the bright side for you.  the 1750 seems to work out all right for your GN, alot better than a 1000 payload would have a few years back.
just think about all those with diesel 3/4 tons using most of their payload for the diesel engine itself. that would make me cuss.
Flush
Posted 2005-05-11 4:42 PM (#24991 - in reply to #24960)
Gabz,
   I too see what you are saying. The manufactures rate the towing capacity so high, but in order to not exceed your payload, you would have use bumper hitch trailer and almost everyone who tows 9,000lb+ trailers wants to use a GN!
All the manfuctures put the tow ratings all over their webpages and advertisements, but try to find the vehicle weights and payload capacities for the diesel models?
It is also interesting how "1/2 ton" and "3/4 ton" trucks have evolved, not to mention to low low payload capacity of some of the diesel 3/4T.
Here is the maximum payloads for 2004 Ford F150 and F250. This is the payload still available assuming there is a 150lb person in each of the 6 seating postions
F150 (5.4L) supercab 163" WB, payload = 1420lbs
F250 (diesel) supercab 158" WB, payload = 1065lbs
Here is where I got the info: https://www.fleet.ford.com/showroom/rv_trailer_towing/2004/2004RVTrailer_SIC.pdf
inWA
Posted 2005-05-11 5:42 PM (#24994 - in reply to #24584)
Yes, just a whole lot of fun, with WD hitches and non-WD hitches. We have the truck set up for both, around town we short hauls BP with WD, long huals and shows we use the GN. I have hauled without the WD being set up without horses. Even then I donot like it, trailer is not as stable as with the WD set on. With horses I want it there makes the hauling a whole lot less stressful. And I hear what you are saying about the bars, when we switched trucks they did not have the same bar lengh, had to have the new chain clips welded on to the proper spot, yep extra money.
momofahorselover
Posted 2005-05-19 3:28 PM (#25322 - in reply to #24584)
Am shopping for a 2 horse/ bumper pull trailer in California and will need to get a trailer hitch for the Landcruiser that will be pulling it... Chicken or egg?  Which first?  And if the trailer hitch for SUV is first what kind is best to get?  I am going have to read this whole thread a few times before these terms start to mean ANYTHING to me so any comments on dos or don'ts are most appreciated!  Thank you!
Posted 2005-05-19 7:20 PM (#25333 - in reply to #25322)
Originally written by momofahorselover on 2005-05-19 4:28 AM
Welcome to the board ... (your name is appros to my situation ..LOL)  Since you've got the Landcruiser already, that's your starting point.  Check with Toyota on the combined gross vehicle weight rating.  The cgvwr is a legal enginering term.  There's no fudging as in "It'll pull it"  It means the combined loaded weight of the LC and the loaded trailer.  That's your max and your starting point.  Everything flows from there.
momofahorselover
Posted 2005-05-20 11:27 AM (#25354 - in reply to #25333)
So these numbers don't look very promising: Curb Weight 5115#s and Gross Weight 6860#s.  So if do the math does this really mean I can only pull 1,745#?  I don't think I know how to tell daughter that we have to trade her Quarter Horse in for a Pygmy Goat!!!!
gabz
Posted 2005-05-20 12:07 PM (#25358 - in reply to #25354)
1000100100100252525
No - you need to check with the manufacturer to determine what the safe towing weight is for the vehicle.. BUT
knowing your base curb weight and the gross vehicle is 1 step.
You need to add up how much you will put in the LC in addition to yourself. (cooler? tack? child? spouse? other children?)  ...  add THAT to your curb weight.
Subtract all that from the gross vehicle weight.
In general... about 10 - 15% of the TOTAL weight of the "bumper" (tag-along) trailer and it's load (horse, hay, etc.)  is what will be transferred to the tow vehicle. (with a gooseneck or 5th wheel type trailer, it's more like 20 - 25% of the trailer weight that is transferred to the truck)
So - if your base curb weight is 5115 and you add 2 people, 1 cooler, western saddle & gear, you are now up to 5465 (let's go to 5500 for simplicity sake).  Then 6860 -  5500 leaves 1360. Which TECHNICALLY allows for a 13,600 pound trailer. BUTBUT BUT BUT BUT BUT... I am sure that your vehicle is NOT rated for that.
Look at the hitch on the back of your vehicle. There are numbers stamped into it. That tells you how much you can tow ON THAT HITCH - NOT NECESSARILY YOUR VEHICLE... with a weight distribution hitch or without one. (weight carrying is NO WDH)... Then, check with your truck manufacturer on maximum amount of towing weight.
The hitch at the back of your tow vehicle must have at least a 2" square receiver. (The part that you slide another piece of metal with the ball attached to it, into must be 2" square).
There are 2 books that I always recommend: "Buying, Maintaining, and Servicing a Horse Trailer" by Neva & Tom Scheve... and one that's got less technical and more photos for the typical horse owner, is the one by Cherry Hill - Guide to Horse Trailering. I STRONGLY recommend that one for your situation as it sounds like you're fairly new to this whole thing. The $20 for the book is a wonderful investment.
let us know what else you need help with.
chadsalt
Posted 2005-05-20 12:58 PM (#25363 - in reply to #25358)
1000100100100100
[QUOTE
Look at the hitch on the back of your vehicle. There are numbers stamped into it. That tells you how much you can tow ON THAT HITCH - NOT NECESSARILY YOUR VEHICLE... with a weight distribution hitch or without one. (weight carrying is NO WDH)... Then, check with your truck manufacturer on maximum amount of towing weight. QUOTE]
umm gabz.... she said she still has to buy the hitch. good post though.to the OP,like everyone has said, call toyota and get the GCVWR for the truck. with the GVWR you stated it appears to be in 1/2 truck territory. as for the hitch, usually there will only be a few choices of hitch manufacturers and usually theyll all be rated at the same weights for that vehicle. call around and look for the best price, tell them you of course want the highest weight rated hitch. a quick look around the web and the hitches i see for the landcruiser (what year is yours?) are rated at 5000/6000 weight carrying/weight distributing. you should be in good shape for a small BP and 1 horses. did i mention call toyota? good luck.
Edited by chadsalt 2005-05-20 1:38 PM
momofahorselover
Posted 2005-05-20 1:27 PM (#25369 - in reply to #25358)
Really appreciate the trailer 101 primer.  I am onto Amazon next.
momofahorselover
Posted 2005-05-20 1:30 PM (#25370 - in reply to #25363)
1999 Land Cruiser  ---- I will try contacting Toyota as well.  Thank you  -- Any brand of BP you care to suggest?
gabz
Posted 2005-05-20 1:48 PM (#25371 - in reply to #25370)
1000100100100252525
There are many good brands of trailer... if you are in southern CA, then you have different considerations than say northern CA. If the trailer can be kept under cover (carport, barn, etc.) is a consideration (that means you can get a stock-type or stock/combo which is lighter and cooler for the horse(s).  Leaving a stock or stock/combo out in the weather is inviting floor rot as all the weather can come in through the slats.
Aluminum is more lightweight on large trailers. Not always true for 2H ... be sure to ask for the empty trailer weight. It's hard to get this info as it is NOT posted on the trailer data plate - it's usually only on the trailer title or cert of ownershp.
You might also strongly consider fiberglass roofed trailers - they will be lighter in weight, more light in side, and cooler for the horse.
If buying new - ask for names & numbers of folks who have bought from the dealer before. Find out how they handle servicing and warranty work. (Some do it themselves, some send it back to the manufacturer, some allow you to find any shop that will do the work and then they reimburse you or pay the bill).
My apologies about the hitch comment - my original thought was that you were unsure about a regular receiver versus a weight distributing.  I would be very hesitant about a tow vehicle that didn't have a factory-installed hitch on it simply because I would wonder if it had the proper cooling system - both engine and transmission - and if it was outfitted properly(suspension and tires) for towing.
Posted 2005-05-20 1:50 PM (#25372 - in reply to #25354)
Originally written by momofahorselover on 2005-05-20 12:27 AM
Momofahorselover ...I believe you're missing my point. The curb weight is the weight of the LC with you and a tank of gas.   You can add up to 1,745 pounds of stuff into the LC before its overloaded (remember 10% of the trailer weight will be part of the 1,745 pounds).  You NEED the CGVWR  number...  It has to have the word "Combined" somewhere.  Otherwise you will not know how much trailer you can safely handle.
momofahorselover
Posted 2005-05-20 1:51 PM (#25373 - in reply to #25370)
Now I am getting more confused.  My call to Toyota parts department said I can pull 6500#s in addition to vehicle weight.  Again this is a 1999 Land Cruiser.
230-hp, 4.7-liter V-8; 4-speed automatic w/OD, 4WD; & Class IV (whatever that means).
Does this makes sense?
Posted 2005-05-20 2:09 PM (#25375 - in reply to #25373)
Originally written by momofahorselover on 2005-05-20 2:51 AM
  Toyota didn't tell you the CGVWR but they told you the max loaded trailer weight you should get.  Figure a horse and tack weighs about 1200 pounds ... so two horses will weigh 2400 leaving the trailer with 4100 pounds empty.  At most, this is a two horse trailer... meaning no living quarters (lol!)
chadsalt
Posted 2005-05-20 2:14 PM (#25376 - in reply to #25373)
1000100100100100
Originally written by momofahorselover on 2005-05-20 1:51 PM
yes it does, that puts the GCVWR in the 11500 region. dont get hung up on the class iv hitch, its easiest just to pay attention to the weight rating in pounds. when a manuf. gives a max trailer weight it is generally the base vehicle curb weight with a 150 (or so) driver subracted from the GCVWR....so reversing the equation your curb of 5115 + 6500 trailer = 11615 GCVWR. be aware however that the 6500 rating is most likely with a weight distrubting hitch. some of this info should be in the owners manual, may i suggest a look through it? if these numbers are close youll have no problem with a 2 horse bumper pull(usually around 2500) and one horse (1000) =3500. im pulling a 2 horse slant w/ dressing room (3500 + 2 horses + tack = 6000)with a similar max trailer rating. i agree with gabz about the book, i would also seek out an individual with towing experiance, preferably with horses, and get some pointers. be safe.
Edited by chadsalt 2005-05-20 2:15 PM
gabz
Posted 2005-05-20 2:19 PM (#25378 - in reply to #25373)
1000100100100252525
That's probably right. The LC is quite a large SUV-type of thing right? (Here in "Detroit" land, we rarely see anything other than domestic built SUVs)
So - if you can tow a 6500 pound load, and you want to haul 1 horse only, all of the time, and NEVER haul 2 horses, you can look for a trailer that weighs about 5000 pounds, empty. However, you might want to consider the "80% for live load" safety factor - which would mean you only want to haul 5200 pounds. With 1, 1100 pound horse, you can tow a trailer that weighs 4100 pounds empty. If you want to haul 2 horses, and the tack and hay, etc., then you want to look for a trailer that weighs 2700 pounds or less, empty. Be sure that the trailer is tall enough inside for the horse(s).
: ) Did you find a book yet?
Then, you need enough hitch for the maximum towed weight. Even if you get under 5000 pounds of towed weight, you might still want a WDH - especially if the wheelbase (length) of the LC is less than say 120" ... (the shorter the wheelbase of the tow vehicle, the more unruly the handling can be) or WDH with anti-sway bars.
As I'm sure you have read - horses will move around and are top heavy - very bad things for a towed load.
Edited by gabz 2005-05-20 2:25 PM
Posted 2005-05-20 2:28 PM (#25379 - in reply to #25378)
Momofahorselover ... We're all (Gabz ,Chadsalt,& I ) telling you the same thing ...
Another subject, if you're hauling one horse in your two horse straight load, you'll want to load him on the driver's side of the trailer.  This will help with trailer stability, because most roads are crowned in the middle to shed water.  And second, if you should run slightly off the edge of the road, the horse's weight will still be on the road.
momofahorselover
Posted 2005-05-20 2:51 PM (#25380 - in reply to #25375)
Good excercise for 17 year year old!  She can figure out how much horse & tack & stuff weighs --- then I will add another 50# for the weight I am gaining sitting in front of computer and eating!  Talked to husband who has the LC out of town and he will check rating on ID tag.
At least we are back to pulling a horse vs a pygmy goat (much harder to ride in reinings)
momofahorselover
Posted 2005-05-20 3:01 PM (#25381 - in reply to #25378)
Just ordered both books from Amazon.  Good point about horses moving...maybe I should be looking into sedatives for horse and myself -- and let daughter drive!
Toyota parts guy also tells me Toyota no longer mfgs the tow package for 99 Landcruiser, they would go with Rigid brand Class III rated at 5000#s
$290 parts including wiring harness + $360 labor.  This is between San Francisco and San Jose, Ca .... prices are generally higher than southern Cal. in most things particularly labor.
gabz
Posted 2005-05-20 3:01 PM (#25382 - in reply to #25380)
1000100100100252525
I don't know ... my pygmy does fantastic sliding stops... at least I think that's what she's doing... maybe she's just sitting down while she's walking? (I've been told she looks like a mobile footstool...)
Reining, eh? I recently got involved with Reined Cow Horse... (NRCHA stuff)... My horse practices the cow work on the full-size and pygmy goats.
momofahorselover
Posted 2005-05-20 6:21 PM (#25392 - in reply to #25382)
Now dad would probably prefer to be feeding/housing/training pygmy goat - though he does have a soft spot for the mare - the one female in his life who doesn't talk too much!
Thanks to all who took time to point a total trailer neophyte in right direction!
