  Location: Colorado | Spent yesterday getting plywood subfloor cut and fitted to install. Today the metal beams got ground off, rust treated, and painted with Zero Rust. Pictures attached... Tomorrow the plywood will get coated with asphalt emulsion and then the subfloor will go in and be done! We decided to install foam board and then a top layer of plywood, as there is plenty of depth in the frame of our trailer for a fully insulated floor. Happy Trails, Michelle |
  Location: Colorado | I couldn't find decent looking pressure treated plywood, so no, we are installing regular exterior rated plywood that we are coating with asphalt emulsion. Michelle |
 Location: Covington, Louisiana | Michelle Thanks for your reply. Since mine is only a small (6' X 8') dressing room, and appearance and insultaion are not as much a concern, I will probably use two layers of 3/4" Pressure treated plywood with a sheet vinyl floor covering on top. Thanks again Russ |
