| Does anyone own a 2000 Exiss SS/400 the Event? I have questions that I can’t seem to find the answers to. |
    Location: Tenn/Ala. | We've sold many of them over the years at our dealership. What kind of questions might you have? There is probably someone on here who can help. |
| I’m trying to figure out where the battery is supposed to be. There is a ground cable in the back, in the tack room, but no positive cable. Also how big of an inverter would I need to purchase to run the a/c, lights, etc.? |
    Location: Tenn/Ala. | Well, it sounds like your trailer has items that were not in it when it left the Exiss factory. Generally, the only time a battery is in the rear tack, is if there's a generator mounted somewhere close by. As to inverter, I have no exoerience with them. As a rule, folks use a minimum of a 3,000 watt generator to run a converter and A/C as that can give you about 25 amps. |
