Sundowner telescoping divider will not slide
wbsherlock
Reg. Apr 2021
Posted 2021-04-06 4:03 PM (#173601)
Subject: Sundowner telescoping divider will not slide
I have a 2007 Sundowner Sunlite slant liad trailer with a rear telescoping divider that is stuck partway out. I have tried WD40 and it is STUCK. Is there a mechanism inside that could be jammed? There is no way to access inside the tubular encasement.
wbsherlock
Reg. Apr 2021
Posted 2021-04-06 4:06 PM (#173602 - in reply to #173601)
Subject: RE: Sundowner telescoping divider will not slide
I will try and attach a photo.
(20210406_190357.jpg)
Attachments 20210406_190357.jpg (51KB - 0 downloads)
RTSmith
Posted 2021-04-08 10:30 AM (#173605 - in reply to #173601)
500100100100
Usually when they get sticky, something has gotten bent. Everything has to be very straight for it to telescope properly.
Posted 2021-04-09 6:25 PM (#173611 - in reply to #173602)
I have a Sundowner too. My divider has gotten sticky. If this is a new situation to you and the divider seems straight ... The internal and external tubes are made of aluminum. It oxidizes, wears, combines with dirt, and forms a hard paste.
Get some penetrating oil. WD-40 is nice, but there are better. Lift the end and squirt into both the top & bottom tubes. Get a rubber hammer and hammer it in, then hammer it out. Any fractional movement is the object. Oil it again and repeat. You're trying to get the oil to flow into the sticking area. It'll be messy, put rags on floor to catch drips. You don't want oil on the mats or floor.
Once you get it extended, smooth any rough surfaces and lubricate them.
Good Luck.
Edited by hosspuller 2021-04-09 6:32 PM
