Riding helmets
garrymrown
Reg. Aug 2020
Posted 2020-08-24 7:19 AM (#173216)
Subject: Riding helmets
What are the best riding helmets for amateur?
Edited by garrymrown 2020-08-24 7:20 AM
garrymrown
Reg. Aug 2020
Posted 2020-08-30 11:23 PM (#173221 - in reply to #173216)
Subject: RE: Riding helmets
I found this interesting review about my question https://webproductradar.com/5-best-riding-helmets
BenAnderson
Reg. Dec 2020
Posted 2020-12-02 8:49 AM (#173378 - in reply to #173216)
I stumbled across this review https://horsezz.com/best-horse-riding-helmets-adults/ while was searching for a helmet. I got the Troxel helmet and I'm totally satisfied with it. Sleek shell, thick padding, and the straps are fine. I'd definitely recommend that gear.
Posted 2021-01-08 9:10 PM (#173418 - in reply to #173216)
The best helmet is the one you will wear every time you're on the horse. Try out a bunch of helmets and decide. Everyone is different when it comes to fit and comfort. No matter how expensive a helmet is, it's not worth a dime if you won't wear it. Conversely, the cheapest certified helmet can be the best if you wear it.
I have a helmet that got destroyed saving my head. It was at a walk and the horse stumbled, I rolled over his neck and landed on a sharp rock like a lawn dart.
Edited by hosspuller 2021-01-08 9:18 PM
Cutter1999
Reg. Jan 2017
Posted 2021-02-26 4:30 PM (#173509 - in reply to #173216)
hoss puller is 100% correct in that it must be a helmet that you will wear. The other important factor is fit- it must fit your head properly.
I came off a horse in September and ended up with a concussion and brain bleed. I also got a helicopter ride to the nearest trauma center.
A Tipperary helmet saved my life. It was cracked through in 3 separate places. I bought that helmet on sale at Riding Warehouse for $79. It was the best $79 I ever spent.
There are now MIPS helmets that are specifically designed to helmet prevent concussions. They are definitely worth checking out.
Edited by Cutter1999 2021-02-26 4:32 PM
BoyOutdoor
Reg. Mar 2021
Posted 2021-03-14 8:41 PM (#173540 - in reply to #173509)
Cutter1999 - 2021-02-26 4:30 PM hoss puller is 100% correct in that it must be a helmet that you will wear. The other important factor is fit- it must fit your head properly. I came off a horse in September and ended up with a concussion and brain bleed. I also got a helicopter ride to the nearest trauma center. A Tipperary helmet saved my life. It was cracked through in 3 separate places. I bought that helmet on sale at Riding Warehouse for $79. It was the best $79 I ever spent. There are now MIPS helmets that are specifically designed to helmet prevent concussions. They are definitely worth checking out.
I think that it's an average helmet. But thanks God it helped as it should! Sad story
LJenkins
Reg. Apr 2021
Posted 2021-04-21 2:50 AM (#173641 - in reply to #173216)
My sister is into horse riding, she usually buys Samshield helmets. Her current one is called Samshield Shadowmatt - not the most expensive one (as far as I remember, it costs less than 500$), but still pretty neat and trustworthy. She usually reads comparative articles and essays online before making the choice, so if anybody needs more info, I can ask her to share her knowledge and/or any useful links.
Glassy
Reg. May 2021
Posted 2021-05-28 8:56 AM (#173728 - in reply to #173216)
Every Friday after employee tracking , I take riding lessons and recently bought my own helmet. I am very pleased with it and the price is nice https://www.doversaddlery.com/dublin-opal-helmet/p/X1-36766/?gclid=C...
