| Will this truck pull this trailer. Any help would be great!
TRUCK
Purchase with confidence from Sparta Chevrolet! This 2012 GMC Sierra 1500 has undergone a rigorous 172-point inspection and we make every effort to ensure that your purchase experience is a great one here at our dealership! Clean CARFAX. 4 Wheel Drive, Remote Vehicle Start, Trailer Tow, BlueTooth, USB Port, Sierra 1500 SLE, Vortec 5.3L V8 SFI VVT Flex Fuel, 4WD, 20" x 8.5" Chrome Clad Aluminum (4) Wheels, 3.42 Rear Axle Ratio, AM/FM Stereo w/CD Player & MP3 Playback, Bluetooth® For Phone, Chrome Door Handles, Convenience Package, Dual-Zone Automatic Climate Control, Electric Rear-Window Defogger, Extended Cab SLE Value Package, EZ-Lift Tailgate, Front Halogen Fog Lamps, Heated Power-Adjustable Black Outside Mirrors, Heavy Duty Cooling Package, Heavy-Duty Air-to-Oil External Engine Oil Cooler, Heavy-Duty Auxiliary External Transmission Oil Cooler, Heavy-Duty Rear Automatic Locking Differential, Heavy-Duty Trailering Package, Locking Tailgate, Power door mirrors, Power-Adjustable Pedals For Accelerator & Brake, Remote Vehicle Starter System, SIRIUSXM Satellite Radio, SLE Preferred Package, Speed control, Steering Wheel Mounted Audio Controls, Tilt steering wheel, Ultrasonic Rear Parking Assist w/Audible Warning, Universal Home Remote.
2012 GMC Sierra 1500 SLE Extended Cab Mocha Steel Metallic 4WD 6-Speed Automatic Vortec 5.3L V8 SFI VVT Flex Fuel
TRAILER
1995 Featherlite 3 Horse GN Weekender
Mfg: Featherlite
Year: 1995
Horses: 3
Model: 3 Horse GN Weekender
New: N
Living Quarters: No
7' Tall, 6'9" wide, 4'8" SW dressing room with Insulated & Paneled walls and ceiling, Some cabinet & shelving, Screen door, Awning, 1st stall has acess door, Folding rear tack with swing out saddle rack, Hayrack, Horse area has insulated roof, Floor Length 17'3" Overall length is 25'
Location: Baker, FL | According to https://dcd96xmek71bc.cloudfront.net/trailerlife.com/2012_towing_gui... which is linked from https://www.trailerlife.com/trailer-towing-guides/, the towing capacity of your truck is 9600 lbs.
You need to determine what the fully loaded weight of your trailer is.
I pull my 2014 (all aluminum) 3H GN Shadow with LQ with my F150 all the time. Considerations: I upgraded the brakes, suspension and tires to be safe and I live in Florida where it's flat! | |
        Location: North Carolina | Are you going to have three horses ? The 3.42 axle ratio will boil your transmission. The gas money you save will go to repairs. | |
     Location: missouri | Not enough BRAKING POWER.... step up to at least a 3/4 ton for safety if you care about your horses. Or, you can learn the hard way like the rest of them. Sorry, good luck. | |
   Location: Minnesota | Pulling is not the issue. Sure it will pull it.
Control and braking is the issue you should be conccerned with and the answer to both are NO.
Edited by DLR 2020-05-26 1:36 AM
