Location: Baker, FL | On my dual axle trailer, I experienced a blowout plus minimal damage on the tire on the same side so I decided to replace both tires. The two tires on the other side are fairly new and in great shape so I didn't replace them. I'm putting one new tire on each side for balance. My question is do I want the new tires on the front or back? The new tires are slightly better (load range E vs D).
Edited by mrarick 2019-10-02 1:38 PM
    Location: Rayne, LA | I am not a tire expert, but if your trailer is level I would not think it would not matters. If the nose is high then I think they would be better in the back. We have some knowledgeable people on here that I hope will chime in. |
Location: Baker, FL | UPDATE: I posted the same question on eTrailer and received the following detailed response:
New tires all around would be ideal. The front axle will usually carry more of the weight, but the rear wheels will wear sooner due scrubbing or skidding on trailer turns.
In addition to front or back consideration, another is also which axle has brakes and is it a straight or torsion axle? If both have brakes then put new tires on the rear axle if it is a regular straight axle; but if the trailer uses torsion axles put them on the front axle.
If no trailer brakes then I would put the new tires on the front axle since it generally carries more of the load than the rear axle.
Because of differences in tread pattern, load capacity, and construction type you may see uneven tire wear, tracking problems, over heating, and suspension issues over time. |
| thanks for posting your eTrailer response. Very interesting and good info!!!! |
     Location: Tenn/Ala. | I'm not sure I agree completely with the thought that the front axle carries more weight. Most horse trailers are torsion axles, and most are running a little higher in the front. With that, there will be more weight on the rear axle than the front. There's no way around it as long as the nose is higher. |
