| i am looking for a scratch and dent tack room outside door for an Exiss trailer. Does anyone know a place that carries these doors. |
| I was just at a semi trailer body repair shop. They were repairing a horse trailer that had been in a storm. Could a business like that rebuild your door or fix it? |
| Forgot to mention there is a Facebook group that folks sell used trailer parts on. Might not be close, though |
| I recommend replacing the door with your own hands because such services often charge too much. Inspect the trailer both inside and out. Look for holes, gaps, or hanging parts. Examine any discoloration, deformation, or separation in seams and joints. Write down the location and description of each problem on paper. Level the trailer by placing jacks under the beams. Place jacks blocks so they don't fall into the ground. As a rule of thumb, the doors can match the 6.6' doors. This is done on purpose, you might say it's the standard. |
| belenom - 2022-05-03 2:50 PM I recommend replacing the door with your own hands because such services often charge too much. Inspect the trailer both inside and out. Look for holes, gaps, or hanging parts. Examine any discoloration, deformation, or separation in seams and joints. Write down the location and description of each problem on paper. Level the trailer by placing jacks under the beams. Place jacks blocks so they don't fall into the ground. As a rule of thumb, the doors can match the 6.6' doors. This is done on purpose, you might say it's the standard. My son and I finished working with our doors in the house yesterday |
