CM trailer inside wall panel replacement
Horselover2000
Reg. Jul 2019
Posted 2019-07-29 12:08 PM (#172569)
Subject: CM trailer inside wall panel replacement
Hello!
This is my first post here.
I have a early 2000s CM Trailers straight load 2 horse trailer.
For the past 5 years a window on the passenger side has been broken/open and has been letting lots of rain water in - most of this has dripped down the wall panel.
The wood on the inside of the trailer wall has rotted - I'm in the process of tearing it all out and I'll be replacing it with plywood. I'm curious about the nuts and bolts holding the external spare tire holder on - these go through the plywood. This will be a problem if I rip all the plywood out.
So,
1. Does anyone have any experience doing this type of job?
2. Should I wedge 3/4in plywood in OR use 1/2in with a little wiggle, and then do I glue it to the metal frame?
3. The internal metal wall is rusted - how do I take care of that?
I've attached pictures for reference.
Thank you!!!
Edited by Horselover2000 2019-07-29 12:17 PM
(IMG_20190624_205214_1.jpg)
(IMG_20190723_181111.jpg)
Attachments IMG_20190624_205214_1.jpg (95KB - 0 downloads)
Attachments IMG_20190723_181111.jpg (96KB - 0 downloads)
Horselover2000
Reg. Jul 2019
Posted 2019-08-05 1:00 PM (#172580 - in reply to #172569)
Subject: RE: CM trailer inside wall panel replacement
UPDATE:
After 3 hours and 1 blister I was able to remove the plywood! Unfortunately, I slightly damaged the outside sheet metal by bending a crowbar against it from the inside to get the plywood off, oh well - nothing I can do about those pointy dents that I'm aware of.
The water damage was worse than I thought - the bottom portion of the metal wall is so rusted that I can poke my finger through it with enough pressure. This is about a 4 inch wide section all along the bottom of the wall, with worse spots in the bottom corners. I'm looking to get a welder to come attach new sheet metal there after I use some rust remover, hopefully thin sheet metal isn't too expensive. After that, THEN I will re-attach the plywood.
There are some screws throughout the wall that I'm going to have to have a lot of faith removing since I think they hold together some part of the frame on the passenger side.
Also, still working on removing the spare tire holder since it will take 2 people to remove the screws as they just keep spinning with no traction - even with WD40.
I've attached pics below:
(1.1.jpg)
(2.1.jpg)
(3.1.jpg)
(4.1.jpg)
Attachments 1.1.jpg (91KB - 0 downloads)
Attachments 2.1.jpg (98KB - 0 downloads)
Attachments 3.1.jpg (97KB - 0 downloads)
Attachments 4.1.jpg (95KB - 0 downloads)
