 Location: Wi | Best thing to do is google vehicle wraps. You are pretty close to Kansas City. There is a place called Rev2 Design that has some good reviews.
Is your trailer painted or raw aluminum? If painted there maybe some ghosting where the old graphics were. If aluminum you may want an acid wash after old ones are removed and new ones applied. This should be discussed with whoever is uninstalling/installing
You will want a premium vinyl. If cut vinyl you will want cast. If printed you will want a cast laminate and cast adhesive vinyl (Arlon 6000XRP or 3M 180Cv3. I would anticipate that the cost (not including design) would be in the $10 per sq ft for printing plus $5 per sq ft for installation. (pricing in your area maybe different, and depending on size how well it uses the media. |
