adding windows to a slide out
nsjunk
Reg. Dec 2015
Posted 2018-04-02 12:25 AM (#171484)
Subject: adding windows to a slide out
is it possible to add two side windows to a existing trailers slide out ?
Cutter1999
Reg. Jan 2017
Posted 2018-04-02 10:01 AM (#171485 - in reply to #171484)
Subject: RE: adding windows to a slide out
Anything is possible if you have enough money!
RTSmith
Posted 2018-04-04 11:52 AM (#171489 - in reply to #171484)
Cutter is pretty close on this one. Yes, you can. You don't mention brand, but most slideout rooms need to be fairly stiff, so any windows were framed in when it was built. Adding them will involve removing enough of the interior to cut the hole, build and place a frame, and weld it all together. Then set the window, reinstall the interior, adding the proper blinds for the new window.
Posted 2018-04-08 12:48 AM (#171497 - in reply to #171484)
Are you talking about adding windows to the external side of the slideout unit...OR to the walls of the slideout that are exposed when the slide is extended??
Edited by PaulChristenson 2018-04-08 12:49 AM
