| Hello everyone! Im new to the forum as Ive discovered it in a search for information relating to a horse and/or livestock trailer that I have inherited. From the research I have done, I've learned that the trailer is a 1992 and nothing more. Basically, I'm hoping to find out all information I can relating to it as I'm interested in selling it because I have no use for it with several other horse trailers on thw property. I will attach photos of the trailer along with a photo of the VIN Plate. Any information related to the make, model, possibly even the worth would be very much appreciated. Thank you all for your time! | |
| Unfortunately, the photos are too large for the forum to upload from my cell, so I'll explain what the trailer looks like and provide the VIN and maybe go from there!
The trailer is 15' long and 6' wide. During my research, something came up that is stuck in my head which is "runabout" but that may not even be del ted to my trailer. It was made as an open top with a tarp as a roof covering. At the rear, the half door will slide right or full door will swing. It has a double axle. It also has the metal gate centered in the trailer for separation. If I remember correctly, I was told it required a 3/4 ton truck or larger to pull it and it is a bumper pull trailer. That's basically the only way I know to describe the trailer. Doing research with the VIN, the only thing I have gathered is that it was manufactured in October 1991 and is a 1992 model. If it helps at all, the VIN is as follows:
1H9TE1121N1057024. Again, any information will be greatly appreciated! | |
