Brenderup solo wheel bolt torque
Posted 2017-10-08 9:20 PM (#170736)
Subject: Brenderup solo wheel bolt torque
I've been told the Brenderup wheel bolts are one-time use. Seems this would be a poor design for a trailer. Further I was told the torque spec was 215 foot pounds.
I am dubious of this information. According to a few on-line metric bolt charts a grade 8.8 14 mm bolt should be 101 ft/#
Can anybody confirm torque # ? or Wheel bolt design ?
PS ...The Solo trailer has 4 bolts per wheel. Perhaps the Baron or other B'up trailers has 5 or 6 bolts.
Edited by hosspuller 2017-10-08 9:22 PM
Steve-O
Reg. Mar 2016
Posted 2017-10-09 12:24 PM (#170737 - in reply to #170736)
Subject: RE: Brenderup solo wheel bolt torque
I know very little about Brenderups -  But i can tell you if you torque the wheels to 215/ft lbs
?You will either break studs, pull threads or never be able to get the lug nut off on the side of the road when you have a flat.
Edited by Steve-O 2017-10-09 12:25 PM
Posted 2017-10-09 1:25 PM (#170738 - in reply to #170737)
 Forget that 215# thing, that's something you read about how big of a torque wrench you may need ....   Use this chart.....   http://countrytrailer.com/uploads/torquespc.pdf
Posted 2017-10-09 5:53 PM (#170739 - in reply to #170736)
hosspuller - 2017-10-09 12:20 AM
Since Brenderup was European...you could use the chart Retento suppled...or you could go with the Brits chart... http://www.ntta.co.uk/law/trailers/wheels-tightening
Posted 2017-10-09 8:49 PM (#170740 - in reply to #170739)
 Probably best to use Paul's chart and disregard the one I listed...!!
  Might look around on this Facebook page.....
https://www.facebook.com/Brenderup-Trailer-Owners-of-America-188465777858611/?fref=mentions
Posted 2017-10-10 1:05 AM (#170741 - in reply to #170736)
Paul ... Thanks for the link ... The Brenderup used AL-KO axles so I think their specs are the most likely applicable.
I believe the source of the 215 foot/pounds was confused about my request. Brenderup does specify 214 foot/pounds for the axle "NUT" and does say it's a one time use. I was asking for the wheel bolt torque... the bolts that hold the wheel rim & tire to the brake drum.
