Location: Tulsa, Ok | Hope someone can point me in the right direction. Last night our trailer (platinum with outlaw conversion) was running on the generator which is an Onan Genset. All the power in the trailer went off. Generator was still humming along. We reset the breaker on the generator itself as well as all the breakers in the trailer. No power came back on. When we get home today we plug it into electric power and nothing in the trailer will come on. The things like lights, water pump, that can run on battery power will operate on battery.
Any words of wisdom?? |
     Location: Los Angeles, Ca. | Try resetting the main trailer breaker. Sometimes you have to push hard to the off position and then back on in order to reset. Could be a problem with the automatic transfer switch but more likely the breaker. |
Location: Tulsa, Ok | beeoerdog - 2017-06-04 5:24 PM Try resetting the main trailer breaker. Sometimes you have to push hard to the off position and then back on in order to reset. Could be a problem with the automatic transfer switch but more likely the breaker.
Thank you. My husband did get MOST of the electric back on when we are plugged in. There is one outlet with a reset button. When he reset all but one circuits (which is four outlets) came back on. Changed the fuse on that circuit but did not fix the issue.
Still no power at all when running on the generator. Possibly the converter? |
