Looking for ideas to replace ceiling on living quarters, just repaired leak.
madison7351
Reg. Apr 2010
Posted 2017-05-28 8:39 PM (#169961)
Subject: Looking for ideas to replace ceiling on living quarters, just repaired leak.
PDGx
Reg. Jul 2011
Posted 2017-05-30 11:22 AM (#169971 - in reply to #169961)
Subject: RE: Looking for ideas to replace ceiling on living quarters, just repaired leak.
I used this 'leather look' paneling from Menards. It flexible enough to bend to match the roof and they have a matching spray to paint the pvc H joints between panels.
It looks real f
Good and has held up very well.
(IMG_2061.JPG)
(IMG_2062.JPG)
Attachments IMG_2061.JPG (23KB - 11 downloads)
Attachments IMG_2062.JPG (29KB - 4 downloads)
Bluerose2001
Reg. Aug 2010
Posted 2017-08-31 4:11 PM (#170473 - in reply to #169961)
I was searching for this exact same thing and saw this post. So I looked up the closest menards to me- Missouri! I googled American Pacific and the factory is just over an hour away from me and in the same town I compete with my horses in all the time (Next Monday even). I called to see if there were any local dealers and sadly there are none. But they do allow walk in purchases so I am in luck!  Just an FYI- this factory is in Holly Springs, MS. I was going to do the faux tin route too until I saw a bad installation picture in a trailer. I'm still considering a leather printed fabric so it is a toss up right now.
HOUSE
Reg. Oct 2008
Posted 2017-09-01 6:23 PM (#170483 - in reply to #169961)
I like the FRP they put on the walls of bathrooms, it comes in texture and smooth.  It is white, and it is impervious to water so if you have a little leak it does not need to be replaced.
HOUSE
Reg. Oct 2008
Posted 2017-09-01 6:24 PM (#170484 - in reply to #169961)
here it is http://www.homedepot.com/p/4-ft-x-8-ft-White-090-FRP-Wall-Board-MFTF12IXA480009600/100389836
Posted 2017-09-03 6:45 PM (#170493 - in reply to #169961)
I used the FRP panels that House recommended. The only issue is they droop a bit. I fastened them directly to the aluminum roof bows. I too am anticipating a future leak so didn't want any wood lathe or supports in the ceiling. I did use SS screws since the roof bows are not insulated. The cold makes the screw heads sweat. But hasn't been a real problem.
