Double axle vs triple axle goosneck horse trailer
Lorimar
Reg. Mar 2017
Posted 2017-03-02 8:25 AM (#169439)
Subject: Double axle vs triple axle goosneck horse trailer
Pros and cons anyone?
Edited by Lorimar 2017-03-02 8:31 AM
Steve-O
Reg. Mar 2016
Posted 2017-03-02 10:14 AM (#169440 - in reply to #169439)
Subject: RE: Double axle vs triple axle goosneck horse trailer
If it is too heavy for 2 axles then it needs 3.  Only problem with 3 is more stuff to buy,  IE.   Tires, wheels, bearings to pack etc...  -   If the trailer is too heavy for 2 axles you probably need a bigger truck too.
Steve-O
Reg. Mar 2016
Posted 2017-03-02 2:16 PM (#169441 - in reply to #169440)
See this
http://horsetrailerworld.com/forum/forums/thread-view.asp?tid=15148
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ttalk&th=740808
Edited by Steve-O 2017-03-02 2:23 PM
HOUSE
Reg. Oct 2008
Posted 2017-03-02 5:04 PM (#169443 - in reply to #169439)
2 is always better than 3. Go bigger rather than more... it costs more but you will be happier down the road.
HorShe
Reg. Feb 2017
Posted 2017-03-02 8:38 PM (#169444 - in reply to #169443)
HOUSE - 2017-03-02 5:04 PM
+1. Better handling on 2.
RTSmith
Posted 2017-03-03 8:29 AM (#169446 - in reply to #169440)
A lot to consider, the first of which you may not have a choice. If it is too much for 2 8,000# axles, 9,000# axles often won't fit very well, then you'll be at 3 7,000# axles. One issue with the big axles is that you can end up with a tire that takes 125 PSI, that most folks don't keep properly inflated. If that same trailer is on 3 axles with 10PR tires, they run 80 PSI.
Also- tri axles have a reputation for less tongue weight, which is a benefit on a LQ trailer. They also spread their load on the trailer frame better. And have more brakes.
And- tri axles scrub badly when turning on hard surfaces.
So- no clear views. Pros and cons to both. Just my opinion.
huntseat
Posted 2017-03-06 6:03 AM (#169475 - in reply to #169439)
1000500100100100100252525
One sure way to get pulled over for a weight inspection...triple axles.  I think that's why we are seeing less of them on the roads now-a-days as people got wise and bumped up their axle rating to keep it at two axles.
HOUSE
Reg. Oct 2008
Posted 2017-03-06 4:24 PM (#169493 - in reply to #169439)
On my horse trailer I have 2 10K axles and when i roll over the scales I am at 22,000 on the axles, I am over the axle rating but under the tire rating.  on my wagon trailer I have 3 7K axles and only weigh in at 18K, I have much more tire trouble on my three axle trailer, the only advantage is that 16" tires are easier to find, and you can get a warrenty on them.  Which in my exerpience is good because you need the warrenty and you will be going through them much quicker. The 16 inch tires last a year and the 17.5 inch tires last 3, but they also cost 3 times as much but i have more piece of mind with them for sure.
HOUSE
Reg. Oct 2008
Posted 2017-03-07 2:26 PM (#169508 - in reply to #169439)
one other thing to consider is that it is cheaper to buy 3 3.5K axles tires and brakes than it is to by 2 7K axles.  Also the trailer does not have to have as stout a frame for triple axles becasue the weight is distributed over a greater area. I personally will never own a trailer that does not have at least 16" wheels,
