Lunde lift
Soozan
Reg. Dec 1899
Posted 2016-09-29 1:18 PM (#168497)
Subject: Lunde lift
I acquired a 2004 aluminum 3 horse trailer. The lunde lift box where you push button to raise the or lower trailer. well it will lower but when I hit to raise, it just makes a noise. My husband thinks it s a cylinoid, but where.
Will lower but will not raise. Frustrated
Posted 2016-10-01 12:18 AM (#168518 - in reply to #168497)
Subject: RE: Lunde lift
Verify appropriate battery voltage. Verify that all wires are attached appropriately. Verify proper function of the switchgear.
Posted 2016-10-04 7:38 AM (#168537 - in reply to #168497)
 After checking the battery voltage, remove and mechanically clean all the battery terminals. Coat each one with a dab of dielectric grease  before reattaching. You can sometimes read the proper voltage through a contaminated teminal, but might not be able to pull the amps necessary for running a heavy draw unit., such as a hydro pump.
