TV signal booster connector cable?
Milo3
Reg. May 2013
Posted 2016-08-15 11:10 AM (#168023)
Subject: TV signal booster connector cable?
My new Merhow with LQ did not come with a TV.  It does, however, have all the TV "hookups" already wired.  There is a signal booster on the wall similar to this one (this is not the exact one, just to give you an idea):
https://www.amazon.com/Winegard-RV-7042-White-Plate-Supply/dp/B000GGL4CG/ref=sr_1_1?ie=UTF8&qid=1471276905&sr=8-1&keywords=rv+signal+booster+cable
My question is, what kind of connector cable do I have to buy in order to connect the TV to the booster, and thereby will be able to utilize the antenna that is on the roof?  I would prefer to hook the TV right to the booster to minimize clutter and cords.  Is this possible to do?  Or, do I need to buy an antenna for the inside, then hook it to the booster from the inside, then turn the booster on?  Seems like a lot of extra equipment that would be in the way so I'd rather hook the TV right up to the booster using a cable if that is possible.  What kind of a connector do I need to buy?
Thanks!
beeoerdog
Reg. Jan 2014
Posted 2016-08-15 1:02 PM (#168025 - in reply to #168023)
Subject: RE: TV signal booster connector cable?
10010010010025
Regular coax cable available everywhere
