Replacement fender for Kiefer horse trailer
dawnbrenn
Reg. Jul 2016
Posted 2016-07-19 2:55 PM (#167715)
Subject: Replacement fender for Kiefer horse trailer
In a freak accident today, I lost the fender and both tires off my three horse slant load 1996 Kiefer trailer. I was able to pick up the fender out of the ditch once the horses were picked up and sent back home thanks to a good friend. I drove to the nearest tire dealer (12 miles) and they had two replacement tires in stock and am now safely back at home BUT I need to find a replacement fender . . .Any ideas?? I live in NW Montana. thanks!
beeoerdog
Reg. Jan 2014
Posted 2016-07-19 3:08 PM (#167716 - in reply to #167715)
Subject: RE: Replacement fender for Kiefer horse trailer
10010010010025
http://www.theoempartsstore.com/product.php?productid=16420&cat=978...
A little more expensive but thicker material
Posted 2016-07-19 3:33 PM (#167717 - in reply to #167715)
http://www.trailer-fenders.com/tandem-axle?gclid=CPHOvM2wgM4CFcQehg...
dawnbrenn
Reg. Jul 2016
Posted 2016-07-20 9:51 PM (#167747 - in reply to #167717)
http://www.trailer-fenders.com/tandem-axle/72x10-3-4-smooth-aluminu... dimensionally this is the right choice but I'm concerned that it may not be heavy duty enough as in the description it talks about using it on boat trailers. Thoughts?
beeoerdog
Reg. Jan 2014
Posted 2016-07-20 10:22 PM (#167749 - in reply to #167715)
10010010010025
Those fenders are fine...... .080 on thickness....the other one above is .090 but either is acceptable
dawnbrenn
Reg. Jul 2016
Posted 2016-07-21 7:10 AM (#167754 - in reply to #167749)
Thanks! I was thinking that would be the case but since I have ZERO experience I appreciate a sound second opinion :-)
dawnbrenn
Reg. Jul 2016
Posted 2016-07-22 10:23 PM (#167781 - in reply to #167754)
I also need to replace the piece shown in the picture . Any suggestions where I can get this and what it's called?
dawnbrenn
Reg. Jul 2016
Posted 2016-07-22 10:33 PM (#167782 - in reply to #167715)
Oops thought I could upload a picture of the part that I need to track down. It is the long hollow aluminum pipe that is attached to the exterior trailer wall behind the tires and runs the full length of the tires and is curved at both ends to follow the fender bend. There is a wiring junction box centered between the two tires on this aluminum pipe and is attached to the exterior trailer wall. The wiring box is a bit bent up and the cover for it is missing. Some of the protective mesh wrap on the wiring got stripped off but the wiring is intact, no bare spots and the brakes/lights work great. I don't know where to begin to find this replacement part without knowing the name for it. Any help??
Edited by dawnbrenn 2016-07-22 10:35 PM
beeoerdog
Reg. Jan 2014
Posted 2016-07-23 12:00 AM (#167783 - in reply to #167715)
10010010010025
Generally called a conduit. Local metal supply should have it or you can order from Amazon. Ebay has some also. Use a conduit bender to make the curves.
