Location: Omaha nebraska | Quick question. When washing and waxing your trailer.. Do you use rv formulated products if so can they be used with a power washer ? Sorry that was two questions?? |
     Location: Penrose, Colorado | I think if you do not use a rv type cleaner and wax in a power washer you will be there forever. I am sure someone else may have an idea on your question also. good luck |
Location: Omaha nebraska | I've read all these posts on cleaning the floors and the inside. But not a lot on maintaining the outside. The reason I can see not to wash the outside is your plates are expired ....... |
  Location: NC | normally we use a pressure washers to knock all the loose debris off then we use turtle wax brand wash that has wax in it and use long soft brush, we then rinse with the pressure washer. then we wax it with turtle wax cabana wax. take a while but looks good afterwards. |
