Posted 2016-06-20 10:05 AM (#167360 - in reply to #167358) Subject: RE: Trailer Fridge won't work
Posts: 350 Location: Penrose, Colorado
un plug the circuit board and then put them back you may just have a bad connection, if that does not work check your grounds and make sure you have power there, it has to have 12 volt to it to work. I had the same problem before and it was the ground.
Posted 2016-06-20 10:33 AM (#167361 - in reply to #167358) Subject: RE: Trailer Fridge won't work
Posts: 5870 Location: western PA
Ditto Kooner. You can buy a rattle can of circuit cleaner, pull the plugs, clean the contacts and reinstall the plugs. A coating of dielectric grease will usually prevent any further problems. You also need electrical when using the propane. Make sure you have power to the circuit board, if not look for a fuse or breaker that is open. Circuit wiring diagrams are available on line for most make and models of fridges. A multimeter and a few minutes of time will usually sort things out, instead of spending hundreds at a dealer.
