truck and trailer weights...new F250 or F350
Terrye
Reg. Nov 2010
Posted 2016-06-04 3:35 PM (#167231)
Subject: truck and trailer weights...new F250 or F350
Hey Everyone,Currently have a 2003 F350 with a 2005 Cimerron gooseneck.The trailer has 2 7000 lb axles.The weights are with my 2 horses, 35 gals water, hay, and a quad in the trailer and 90 gals water in the bed.I am looking at a new F250 or F350 and wanted room for growth so I weighed my trailer.Here are the results:Steer Axle 4460Drive Axle 5440Trailer Axle 8220Total Axle 18320Truck 8360Trailer 9960Total 18320So F250 or F350?Thanks,terry
Terrye
Reg. Nov 2010
Posted 2016-06-04 3:48 PM (#167232 - in reply to #167231)
Subject: RE: truck and trailer weights...new F250 or F350
Here it is cleaned up:Hey Everyone,Currently have a 2003 F350 with a 2005 Cimerron gooseneck.The trailer has 2 7000 lb axles. and I put some insulation and a mattress some carpeting tack dog stakes chains, Honda 2000 generator, microwave etc in the tackroom and carry dogs/dogcrates and a boot box etc. The weights are with my 2 horses, 35 gals water, hay, and a Honda 250 quad in the trailer and 90 gals water in the bed of the truck.I was pretty surprised that the trailer was about 10,000 lbs with the quad and two horses in it.I am looking at a new F250 or F350 and wanted room for growth so I weighed my trailer.Here are the results:Steer Axle 4460Drive Axle 5440Trailer Axle 8220Total Axle 18320Truck 8360Trailer 9960Total 18320So 2016 F250 or F350?Thanks,Terry
bjhouten
Posted 2016-06-04 4:08 PM (#167233 - in reply to #167231)
5002525
You need to check the rating on the truck you are planning to buy. I have a 2013 Ram single axle 3500 and that weight is right at my max. You may need to consider a dually.
Posted 2016-06-04 4:22 PM (#167234 - in reply to #167231)
https://www.fleet.ford.com/resources/ford/general/pdf/towingguides/2... CHECK PAGE 19
Edited by PaulChristenson 2016-06-04 4:23 PM
Posted 2016-06-04 4:27 PM (#167235 - in reply to #167234)
Here is the location for the current towing numbers by vehicle... https://www.ford.com/towingguides/
ThreeCW
Reg. Apr 2014
Posted 2016-06-06 10:46 PM (#167246 - in reply to #167231)
Terry,
Here are links to a few previous discussions on truck sizing that may help you to size a truck for your trailer:
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=206...
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=203...
Also have a look at the “sticky” on this subject at: http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=182...
Regards, ThreeCW
calamityj
Reg. Jun 2005
Posted 2016-06-07 6:37 AM (#167248 - in reply to #167231)
500100252525
Why would anyone buy a 3/4 ton truck anyway??? Single wheels v Dual wheels= STABILITY.
Dbarnes72
Reg. Dec 2015
Posted 2016-06-07 4:07 PM (#167252 - in reply to #167231)
Why would anyone buy a 3/4 ton truck anyway??? Single wheels v Dual wheels= STABILITYAre you serious?? How bout McDonalds drive-thru etc. etc. Different needs for different seeds. Be helpful if you have to respond.
Posted 2016-06-07 6:09 PM (#167253 - in reply to #167248)
Originally written by calamityj on 2016-06-07 9:37 AM
Fuel consumption when NOT towing and relatively small trailers(4 horse non-LQ) when towing...means they can get by with a 3/4...:)
huntseat
Posted 2016-06-07 6:21 PM (#167254 - in reply to #167231)
1000500100100100100252525
Really? 3/4 ton, no CDL...1 ton, CDL. Knowing what I know now I'm not sure I would have picked my dually, I'm wrapped in a government crap storm all because I wanted to be more safe. See the pre trip CDL post.
hornet
Posted 2016-06-07 9:05 PM (#167255 - in reply to #167254)
One ton does not = CDL.
huntseat
Posted 2016-06-07 10:01 PM (#167256 - in reply to #167231)
If you tow more than a 10,001 lb trailer and a combined weight of 26,000 you do need a CDL (or a membership with the bar.) Your farm tags will only get you so far and then you'll find yourself up the same creek I am...had I picked a 3/4 ton I'd be sitting pretty at 24,000 lbs instead of unhapply inside of CDL territory at 28,000 lbs. https://www.dps.state.ok.us/dls/pub/NCDL.pdf
hornet
Posted 2016-06-08 4:27 AM (#167257 - in reply to #167231)
There's the problem, farm tags. By using farm tags you are attesting to making money with your truck. Otherwise, no CDL needed. I have researched the hell out this, I drive a C4500 and don't need a CDL. I'm registered with 30,000 lbs plates, NOT farm plates for this very reason.
But we're getting off subject so I'll back out.
RTSmith
Posted 2016-06-09 8:34 AM (#167261 - in reply to #167257)
Originally written by hornet on 2016-06-08 4:27 AM
Please be careful generalizing, as each state is different. In Tenn., Huntseat is correct. And to go further, in TN a regular license plate caps you at 9,000# total weight. So to go higher as any towing rig will, you go with a Commercial or a Farm plate of the proper weight rating. Those are the only 2 options.
From my experience, should your rig be checked (assuming truck & trailer GVWR add to over 26,000) in Tenn, Ga, SC, and some others you'll be grounded until a CDL driver can come move your rig. Not saying it is or isn't right. But have seen it happen in all 3 of those states over the past 15 years.
hornet
Posted 2016-06-09 10:10 AM (#167262 - in reply to #167231)
I pulled through a TN weight station, they waved me on, said I didn't need to stop because I wasn't commercial.
RTSmith
Posted 2016-06-09 4:26 PM (#167266 - in reply to #167262)
Originally written by hornet on 2016-06-09 10:10 AM
I've had that happen too. Then I've also seen an officer ground a 1 ton truck and 24' stock trailer (that had only 2 horses in it). And to make it even trickier, you may get three different answers on three different days.
dgeesaman
Posted 2016-06-13 11:05 AM (#167290 - in reply to #167231)
If the question is between an F-250 SRW and F-350 SRW, the answer is F-350.
If the question is between dually and SRW, it depends.
If the question is legality and licensing, it's another thread. I can say for sure it varies depending on where you go, whether anything on you can be considered even remotely commercial in nature, which cop you're talking to, and the time of day. Enforcement vaguely resembles the law.
