generator in hayrack
okiedokie
Reg. Mar 2016
Posted 2016-03-23 4:04 PM (#166538)
Subject: generator in hayrack
I am trying to mount a portable generator in my hayrack. When I do this it vibrates the trailer. Has anyone done this before and successfully eliminated the vibration?
kooner
Reg. Jun 2011
Posted 2016-03-23 4:58 PM (#166539 - in reply to #166538)
Subject: RE: generator in hayrack
if your hay rack is not loose and the generator is bolted down you should not have a true vibration, but you will be able to tell that it is running. If you are trying to tie it down with straps instead of bolts that may be your problem.
Posted 2016-03-24 3:05 AM (#166547 - in reply to #166538)
Do you have isolation mounts? https://www.grainger.com/category/vibration-isolator-pads/mounts-and...
okiedokie
Reg. Mar 2016
Posted 2016-03-24 6:21 PM (#166554 - in reply to #166538)
I have isolation mounts that I bought locally, I'm thinking they are too big.
Posted 2016-03-24 10:46 PM (#166555 - in reply to #166538)
Old Volvo motor mounts work well
Tankerbell
Reg. Nov 2009
Posted 2016-03-30 7:46 PM (#166625 - in reply to #166538)
Is there any advantage/disadvantage to mounting in the hay rack vs. manger besides manger storage space?
kooner
Reg. Jun 2011
Posted 2016-03-31 7:01 PM (#166630 - in reply to #166538)
for me it is less chance of the exhaust entering the trailer, mine is on top rear and the exhaust pipe extends a little past the rear of the trailer I also think it is quieter being outside.
