fuses for Sierra 8ft shortwall on Exiss Sport
1debrathomas
Reg. Mar 2016
Posted 2016-03-09 4:42 PM (#166412)
Subject: fuses for Sierra 8ft shortwall on Exiss Sport
While replacing/checking fuses a 3 was replaced with a 5. There may also be one other with similar problem.
I don't have a schematic showing which fuse is for what.
Could somebody please help?? My hotwater heater switch won't work (I think it is because of the fuse) and my frig won't work on propane. My guess is that the 2 may be related, but I don't know what size should be in what spot. Any help is extremely appreciated
Spin Doctor
Reg. Nov 2008
Posted 2016-03-09 4:49 PM (#166413 - in reply to #166412)
Subject: RE: fuses for Sierra 8ft shortwall on Exiss Sport
In my opinion, changing the fuse to a 5, will not hurt anything and as long as fuse is good, is probably not the issue.
Most propane water heater and gas refrigerator issues are one of two things-you need to "bleed" the line to allow propane to enter the fire box, or the spark igniter contacts are dirty. A google search of either should help. Some times, the themo-coupler can also be at fault.
As far as a schematic, contact the LQ company if possible.
Good luck!
1debrathomas
Reg. Mar 2016
Posted 2016-03-09 5:08 PM (#166415 - in reply to #166412)
Thanks. Hotwater heater switch won't even light up/turn on and the LP on the frig hasn't worked since we bought the trailer (used) and we changed the thermal coupler. Oh well, may just have to take it in.
Posted 2016-03-11 1:54 AM (#166422 - in reply to #166412)
To check your Fridge... https://rv-roadtrips.thefuntimesguide.com/2014/02/rv-refrigerator-re...
Posted 2016-03-11 1:58 AM (#166423 - in reply to #166412)
To check your Hot Water Tank... http://www.doityourselfrv.com/rv-water-heater-basics-types-maintena...
