Location: Stafford, VA | I just got a new horse trailer :-) it's a hoosier bandit, 8600lbs empty, 13k loaded, and need to replace my tires on my Ford 2009 F250 diesel. Need advise to what tires I should get. I'm looking at the On-/Off-Road Commercial Traction Wrangler DuraTrac, which are 10ply. Advice, feedback?Lisa |
        Location: Vermont | Originally written by lvignerot on 2016-02-04 11:06 AM
I just got a new horse trailer :-) it's a hoosier bandit, 8600lbs empty, 13k loaded, and need to replace my tires on my Ford 2009 F250 diesel. Need advise to what tires I should get. I'm looking at the On-/Off-Road Commercial Traction Wrangler DuraTrac, which are 10ply. Advice, feedback?Lisa A B8209? With 6000 lb axles? |
       Location: western PA | There are many brands of tires that will work on your truck. BF Goodrich, Goodyear, Michelin, Cooper are a good few. E range 10 ply are a minimum. Do not consider any Chinese brands, some owners have had good results with Korean commercial brands. |
Location: Stafford, VA | Yes, it is the 8209. I like it so far in the couple trips I've done with it.
Lisa |
  Location: NC | you are over loaded for 6k pound axles... unless there are 3 of them. |
        Location: Vermont | Originally written by postlewaitee on 2016-02-05 2:07 PM
you are over loaded for 6k pound axles... unless there are 3 of them. Not overweight if they have 20% on the pin...2700 lbs....so 13500 - 2700 = 10800 on the trailer axles |
        Location: Vermont | Time for a trip to the scales and determine your axle loads... |
       Location: western PA | The OP said she is buying tires for her truck |
      Location: Rocky Mount N.C. | Know nothing about them , best I can do.... http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel... |
