Squeaky trailer doors
eswlnu
Reg. Mar 2009
Posted 2016-01-28 10:29 PM (#165962)
Subject: Squeaky trailer doors
What do you all use or how do you get your doors to keep squeaking???
Posted 2016-01-28 10:46 PM (#165963 - in reply to #165962)
Subject: RE: Squeaky trailer doors
I use synthetic automotive power steering fluid, applied with an old syringe. It easily lasts a couple of months in all sorts of weather, and protects the hinges from rusting over the winter months. Some manufacturers have zerk fittings that allow you to use a grease gun. Synthetic products are the longest lasting lubricants, that are readily available.
Posted 2016-01-29 5:38 AM (#165964 - in reply to #165962)
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!Penetrating oil . Average load .. Price per fluid ounceNone ................. 516 pounds .WD-40 .............. 238 pounds .. $0.25PB Blaster ......... 214 pounds .. $0.35Liquid Wrench ... 127 pounds .. $0.21Kano Kroil ........ 106 pounds .. $0.75ATF-Acetone mix.. 53 pounds .. $0.10The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
cajunmuleman
Reg. Oct 2011
Posted 2016-01-29 7:59 AM (#165965 - in reply to #165962)
I use CRC Ultalite 3-36, it doesn't attached dirt or dust and as an aerosol it is easy to apply
calamityj
Reg. Jun 2005
Posted 2016-01-29 8:33 AM (#165966 - in reply to #165962)
500100252525
We use oil-less Silicone spray.
Posted 2016-01-29 10:15 PM (#165968 - in reply to #165962)
Acetone evaporates pretty quickly and offers no long term protection. The best penetrating mixture I've used for stuck threads is a 50- 50 mixture of Kroil oil and brake fluid. It works very well with bolts, nuts, anything threaded or pinned. If the area can be heated, it's affects are even better. If the rusted area offers some movement, a grade of light weight oil will usually loosen things after movement and subsequently being lubed. If the hinges are frozen with rust, the procedures Paul spoke of becomes necessary to free the hinge, which is then lubed to maintain the motion.
eswlnu
Reg. Mar 2009
Posted 2016-01-29 11:21 PM (#165969 - in reply to #165962)
The hinges are free but they are gummed up and are kind of tight. So I have to loosen them up then lube them up.
Posted 2016-01-30 4:03 PM (#165971 - in reply to #165969)
10w30 Mobil 1 full synthetic here, maybe lube everything once a year......
