Hay pod
Kidrdo
Reg. Dec 2015
Posted 2015-12-05 1:49 PM (#165506)
Subject: Hay pod
What to add hay pod to top of trailer. Which is best to get and I'm also gonna move generator out of tack room and put up top. Thank you
301duster
Reg. Jan 2009
Posted 2015-12-05 5:39 PM (#165507 - in reply to #165506)
Subject: RE: Hay pod
I bought one for 4 star and just welded some 1x3 rectangle aluminum skids to the bottom. Then mounted it in front of the hay rack on a C & C. Looked kinda funny but I could store a lot of hay! Used 4-3/8" bolts to mount it. That way I could remove it.
Posted 2015-12-05 5:54 PM (#165508 - in reply to #165506)
Make sure the pod is supported by the sidewalls and not the roof. Be careful if you are mounting an aluminum pod to a steel roof. You will need to isolate any joints of the mixed bimetals.
Posted 2015-12-06 8:28 AM (#165509 - in reply to #165506)
http://www.thetrailerplace.com/product/dj-custom-hay-pod/
Posted 2015-12-06 8:28 AM (#165510 - in reply to #165506)
http://www.hayrak.com
Posted 2015-12-06 8:29 AM (#165511 - in reply to #165506)
http://www.shetrontrailers.com/hayPod.htm
postlewaitee
Reg. Jul 2014
Posted 2015-12-07 8:09 AM (#165520 - in reply to #165506)
http://www.shetroncustomtrailers.com/windowsticker.php?UniqueID=226...
