   Location: Phoenix AZ | Will someone please explain to me what self adjusting brakes are? And do they operate with the brake controller in the truck? My new "used" 2009 Circle J trailer has these brakes but don't seem to be working like my old WW trailer brakes did. In other words, when I engage the manual lever on the brake controller in the truck the trailer brakes don't seem to be engaging. Same when I brake...the trailer brakes don't seem to be engaging. Thanks. | |
     Location: Los Angeles, Ca. | Have you inspected the brake shoes? Anyway, here is a little bit of info: https://www.heartlandowners.org/showthread.php/25101-Dexter-Self-Adj... Problem could also be with wiring, grease from failed seals,etc. | |
       Location: western PA | If the brakes don't appear to be working when the manual over ride is engaged, check the plug's spade pin in the 5 o'clock positio,n when the controller is being used. You should have a reading of at least 12V DC. The other thing to check is the adjustment of the brake shoes within the drums' assys. If they haven't been recently adjusted, they may be too far from the drum to be effective. Some self adjusting brakes are activated by manually applying the brakes when you are travelling rearward. This may take several applications to affect. If the brake assemblies haven't been inspected in a while, it's a good time to have the drums pulled, with all the linkages, brake shoes, drums and magnets being inspected. While everything is apart, have the wheel bearings inspected and repacked with new seals and synthetic grease. The self adjusting brakes won't adjust correctly if the linkages are rusted or broken, or if the brake shoes are well worn. Initially, after their installation, the brakes usually have to be manually adjusted to equalise their activation. | |
   Location: Phoenix AZ | Thanks beeoerdog and Gard, sounds like it's time to take the trailer in to the shop! | |
