     Location: Tenn/Ala. | Rotate the spring up, so that it is pivoting parallel to the floor. From your pics, simply pull it out/up 90 degrees. Once that's done, the long arm sits against the screw you see on the bottom of the divider and will apply tension to the divider. |
