      Location: Florida | Have had one for about a year+ now. Using it in our 4horse slant load aluminum LQ. Have the camera on the butt side of the trailer mounted at ceiling level right down the divider wall. The antenna is just stuck between the screen and the window of the front stall on the right of the trailer. I do have it worked to a 12v switch inside the side walk door. The monitor is mounted on the transmission hump and the antenna is on the back of the cab behind the passenger side. It does what it is supposed to do, nothing special. The picture is good and only get a bit of static when under power lines. I have not used it as a backup camera, but believe you can get cameras with a reversed image. You can email them - they do answer promptly. Been a good camera - no regrets.  |
