Posted 2015-07-19 2:43 PM (#164108) Subject: water tanks
New living quarter owner question: I am trying to fill my water tanks for the first time. I have water coming out under the trailer about as fast as I am pumping it in. :( Was told there are winterizing valves to drain the tanks which are probably open. Where are they?
Posted 2015-07-19 8:09 PM (#164111 - in reply to #164108) Subject: RE: water tanks
Posts: 5870 Location: western PA
There may be a drain near the lower feed connection from the tank. Many installations will have a drain valve near the outlet from the tank. They may be either a ball valve or push pull type. They may or may not be located directly over the actual drain spot of the trailer, if a drain line is used.
