   Location: pineville,mo | Lunde 12 volt system, monarch hydraulics,model 3530, getting power to cellunoids tried switching them and jack will still only raise not lower ,talked to monarch and lunde which is now magnum lift,if I turn the pressure realeses on both cellunoids it will lower by the hand jack or the lower button either one |
   Location: pineville,mo | There are 2 red cellunoid boxes one on each side ,and have small push in and turn releases on them and only one wire to each |
    Location: Topeka Ks | Sounds like you have a bad lower solenoid coil, but I'm not sure. Here's a link to a troubleshooting guide. It will download a pdf. http://www.bucherhydraulics.com/bausteine.net/f/9364/500_Troublesho... |
   Location: pineville,mo | Tried switching them but didn't help,been on phone with monarch, will keep ya''ll updated thank ya |
