Aluminum floor and Duplicolor: What is the latest advise with new?
g-dog
Reg. Mar 2014
Posted 2015-04-11 7:34 AM (#163126)
Subject: Aluminum floor and Duplicolor: What is the latest advise with new?
I am going to apply a bed liner to my aluminum floor...not sure if Duplicolor is the same formula as it used to be so does anyone know if it still is the best to use? I have found through researching Raptor spray in bed liner, it is the best for stock/horse trailers and urine? Any thoughts?
Posted 2015-04-14 8:55 PM (#163159 - in reply to #163126)
Subject: RE: Aluminum floor and Duplicolor: What is the latest advise with new?
Duplicolor makes two products for coating truck beds. Their "Truck Bed Coating" is a vinyl polymer product that has been available for some time. It works well on steel and aluminum, and has been successfully applied by many DIYers. Their "Bed Armor" is a newer product that is water based and has Kevlar reinforcing. It can also be used on steel or aluminum as well as wood. Both of these are single part, cold applied products. I personally have used both on various projects without issues, and am very pleased with the results.
g-dog
Reg. Mar 2014
Posted 2015-04-15 4:55 AM (#163161 - in reply to #163126)
Thank you Gard...I was hoping you would share your expertise!
diggerdoo
Reg. Oct 2009
Posted 2015-04-15 8:03 AM (#163164 - in reply to #163126)
And don't walk on your nice clean floor after  you put the acid on it!!!
Lala80
Reg. Aug 2015
Posted 2015-08-07 12:15 PM (#164372 - in reply to #163159)
Hi Gard, Thank you for all the great info. I am wondering if the ammonia from their urine will do any damage to the coating?
Posted 2015-08-07 8:33 PM (#164376 - in reply to #163164)
Originally written by diggerdoo on 2015-04-15 8:03 AM
Posted 2015-08-09 4:21 AM (#164384 - in reply to #163126)
The bed liner materials will provide an impervious coating that will protect the aluminum from the corrosive affects of urine and manure. The statements about walking upon the flooring, is in reference to contamination of the flooring after it is cleaned with the acid, and before the liner material is applied. Between the two tasks, I take off my shoes and walk in stocking feet whilst applying the liner materials.
Tx. Vaquero
Reg. Jun 2006
Posted 2015-08-09 9:23 AM (#164385 - in reply to #163126)
Don't forget the etching/bonding primer.
Posted 2015-08-10 8:23 PM (#164402 - in reply to #163126)
1000500100100100252525
that is good advice
