  Location: Tomball, TX | My '94 4 Star has extruded aluminum sides - not the wavy style but more angular (not sure how to explain this). How do you install an external gravity-fed water inlet hatch (to the fresh water tank) and seal it off on the outside of the trailer? Does there need to be a frame on the inside to attach the inlet hatch? |
(DSCF1691 - Copy.JPG)
Attachments ----------------
DSCF1691 - Copy.JPG (65KB - 168 downloads)
     Location: Penrose, Colorado | most I have seen from your description are mounted as solid as possible and then caulked in to seal it, that is the way my power plug in is on our trailer. |
  Location: Tomball, TX | Thank you, kooner. Finally figured out how to upload a proper-sized photo. Looks like it will need a lot of caulk. |
     Location: Los Angeles, Ca. | you can also use some spacers between skin and frame of hatch (plastic or aluminum) |
  Location: Tomball, TX | beeoerdog where would I find those spacers and would just any inlet hatch work (depending on what appeals to me) :) |
     Location: Los Angeles, Ca. | You make them....go to hardware store and buy small piece of right thickness...cut to size and drill holes to match |
