best paint for horse trailer?
cascadia
Reg. Apr 2005
Posted 2015-01-11 10:58 AM (#162263)
Subject: best paint for horse trailer?
I can save quite a bit of money if I supply the materials. Tractor paint is well priced but I want a long-lasting durable and rust resistant finish. Is there any particular brand or formulation I should look for?
kooner
Reg. Jun 2011
Posted 2015-01-11 1:01 PM (#162264 - in reply to #162263)
Subject: RE: best paint for horse trailer?
if it is a nice trailer and you are keeping it ? I would not put anything but good automotive or air plane paint on it, you will get what you pay for in paint.
Posted 2015-01-11 8:57 PM (#162271 - in reply to #162263)
If it's an aluminum trailer, an etching primer should be used. If it's steel, a conversion primer can be used. High build epoxy primers can then be added, if it's keen to obtain the smoothest finish. Both metal constructions can then use automotive urethane paints for the final finish. Aircraft and marine paints typically have higher solid contents, that allow complete coverage with fewer coats, but cost more. They are generally better in UV protection.
cascadia
Reg. Apr 2005
Posted 2015-01-12 10:10 AM (#162272 - in reply to #162263)
Thanks! I'm reading up on Imron Elite single stage paint made by dupont. Expensive but might be worth it for a keeper.
Posted 2015-01-13 9:25 AM (#162275 - in reply to #162263)
http://www.jamestowndistributors.com/userportal/search.do?refineTyp...
ue=Awlgrip&page=GRID&engine=adwords&keyword=awlgrip&gclid=CMPI0pO-kcMCFZAvgQodfzEAQg
Posted 2015-01-13 9:31 AM (#162276 - in reply to #162263)
http://www.jamestowndistributors.com/userportal/show_product.do?pid...
