Location: Maryville | I have a 2015 F-350 SRW Fx-4 11500# GVWR. I'm looking at a 1998 Sundowner 8012, I believe 727, all aluminum. My question is, with airbags, will my truck be level enough and stable enough? The trailer has a 32' box. |
      Location: Decatur, Texas | Originally written by ConnorT on 2014-10-18 6:34 PM
I have a 2015 F-350 SRW Fx-4 11500# GVWR. I'm looking at a 1998 Sundowner 8012, I believe 727, all aluminum. My question is, with airbags, will my truck be level enough and stable enough? The trailer has a 32' box. One thing check before you damage the top of the bed I the clearance between the bed rail and gooseneck of the trailer.Ours is a 2004 8010 with a little bit of a dropped nose so if I use a truck with a regular bed I have to really watch the rails. And there is NO way I can use a 4x4 truck that has a regular bed because the bottom of the gooseneck part of the trailer hits the top rear corners of the bed. So without seeing you set up I would say it should be plenty stable but will be really UN LEVEL to clear the bed. |
