My wife just bought a new Titan 14' bumper pull trailer and she asked me to mount a rubber bumper on the back of the floor. This trailer has a 2" square tube across the back, it's maybe 3/16th thick steel. There is no way to use bolts/nuts since the back of the tube is welded to the frame.
I thought about drilling and tapping holes but there would be so little thread, I doubt if it would hold the weight of a horse.
Any thoughts on how we can get a bumper on there?
Thanks! |
     Location: Penrose, Colorado | why not drill all the way through the 2" tubing and then just use longer bolts?? I have seen it done this way and then rhino line the top of the tubing that shows. |
Location: Norfolk, NE | That was my plan, but the back of the tube is welded to the back of the floor bracket. Hard to explain. the attached (very crude) drawing will show what I'm up against. Gray represents the wooden floor boards.
(bumper.jpg)
Attachments ----------------
     Location: Los Angeles, Ca. | Weld on some studs....tell your wife you need to buy a welding machine so you can make her happy. |
Location: Norfolk, NE | That was the plan. Again, my drawing is very crude, but notice that the flooring is shoved into the open side of the U shaped tube. Because there is 2" of steel covering the top of the floor boards, the only way I can see getting a nut on the end of a bolt, would be to remove each of the floor boards, drill the holes, insert the bolt from the back side through the rubber bumper and then get a nut started on the other end. Before I can put the floor boards back in there, I'd have to notch the end of the floor boards to allow room for the bolt end and nut.
Getting the floor boards out looks to be near impossible. There is a slant wall that separates the stalls and the tack room. It's welded in place and cannot be moved. Unfortunately, the floor boards do not stop at that wall, they go under that wall and end in the nose of the trailer.
I feel so stupid for not looking for this things before buying it.
I really do appreciate the help.
     Location: Los Angeles, Ca. | can you use an angle iron and hang from top of channel? |
Location: Norfolk, NE | That may well be what I end up doing. I contacted Titan and was surprised when I received a call. He asked that I give him a few days to work on it. He said they would send me any materials needed to add the bumper.
Even if it turns out that they cannot, I feel good just knowing that they tried.
Thanks for all of the suggestions.
I'll let you know if, and how, we add a bumper. |
    Location: Rayne, LA | Send me your email and I will send you pictures of what you want. I forgot how to attached pics here. My email is cajunmuleman@yahoo.com |
Location: Norfolk, NE | Thank you, I will do that. I appreciate the help. |
        Location: North Carolina | Is the end of the tube open? Perhaps toggle bolts would suit your purpose. If you need to remove the bolts, unscrew the toggle and retrieve it from the end of the tube. |
Location: Norfolk, NE | The ends of the square tube are sealed, which would not be that hard to open up. Titan strongly discourages owners of this line of trailer from modifying the frame in any way. I asked about extending the fear of the floor with additional materials and was told I should not extend the length of the frame even by just a few inches.
So, the bumper I just bought will end up in the trash.
Oh well, thanks to all for your suggestions.
        Location: North Carolina | Wait ... don't trash the bumpers yet... You could have a lip welded to bridge the gap between the rubber and the tube. Then weld a strip of metal across the length of the tube. The combined metal thickness will support drilling and threading holes to secure the rubber bumper. Plug welds around the threaded bolt holes would be the strongest method of reinforcement. |
        Location: North Carolina | Another thought is blind nuts or threaded inserts. There are many different types.Here a link to one... http://www.mscdirect.com/product/details/09331208 |
