| I bought a blanket bar to add to my dressing room in my aluminum over steel trailer. I have had the rack for almost a year as the direction say to make sure to attach to the studs of the wall. I cannot find the studs. If i go all the way through the wall, it goes into the horse are - not something I want to do either. Any tricks for finding the studs?Thanks |
Location: Bryan Tx | Can you look inside the horse quarters and get a measurement and use that inside the tack room. Is the tack in the back of the trailer. |
     Location: Los Angeles, Ca. | Look for other fasteners or try using a magnet |
| Thanks, the dressing room is in the front of the trailer. I just spent time banging with a rubber mallet and a hammer. It seems less hallow horizontally. I see where there are other things attached - the bar does not fit the dimensions. Are studs in trailers horizontal? Finally, I decided to just "go for it" I cant get the first screw to go through. I tried driving a nail through, drilling a hole. I have attached hooks in the past in the side wall. It was tough but doable. These are sheet metal screws. What do you use to get through this stuff? I can't get through the wall that I want the blanket bar on. It is the wall that divides the dressing room from the horses. Inside. |
     Location: Los Angeles, Ca. | Easiest is to use self tapping screws and a cordless drill. Or drill a small pilot hole and then use the screws......by hand is difficult......use a cordless drill. |
       Location: western PA | Setting a self taping screw into steel is increasingly difficult at the thickness of the metal increases. Trying to punch a hole in steel with a nail is almost impossible, maybe probable in some thin aluminum. As was stated, a drill and bit close in size to the outside diameter of the screw, will be necessary to start a pilot hole. Self drilling screws with cutting tips are available. If the sheeting is aluminum, don't use steel screws, instead use stainless. I find the easiest way to locate a stud in a wall, is the use of a plastic handled screw driver. It makes a distinctive sound when the panel is over a backing such as a stud, which usually is vertical. |
| Thanks you for your help everyone. Not sure if I found the stud but it was so hard to get the screws (self drilling stainless steel) in that I hope they do not ever come out. |
