 | Apologize if this question as been asked before...Can a Super Cab F150 5.5 Short Bed truck be equipped with an extender to safely pull a Gooseneck Trailer?  GCWR is 17,100 pounds.  Prefer a short bed truck as it will be our daily driver.  Thank you for your suggestions. |
 | To clarify - the truck we are looking at is a Super Crew (not a Super Cab). |
 | It all depends on the width of the trailer, the shape of its nose, and the placement of the pin. A tapered or rounded nose on a 7' wide trailer can be carried on some short bed trucks. A square nosed 8' wide trailer usually cannot. |
 | As Gard said- maybe. There are step back couplers available for most trailers. They can help a lot.
 I can't imagine you'll need to worry about having an 8' wide trailer on a F-150 anyway. Which does bring up the "oayload capacity" of the truck, which determines how much pin weight you can handle. That may be as large a factor as anything, rather than GCWR.
 A lot of new 1/2 tons have impressive tow ratings, for bumper pulls. The payload is light. Actually a problem still with many of the 3/4s as well.
 | The payload capacity is 3,100.  Is this sufficient for a two horse GN with a small dressing room? |
 | Look on your owners manual for towing capacity. In any event, I don't think you have a problem with either pin weight or max CGWR. Ford specs are online if you don't have your owners manual. |
 | Ford specs state that (Super Crew):(2) Vehicles equipped with 5.5' box will accept a 5th-wheel hitch, but current 5th-wheel trailer designs are not compatible with 145" wb. Crew Cab). I called a trailer company today - they said the vehicle could handle a small two horse gooseneck trailer with a four inch extender.  Called the hitch company and they said my vehicle could not handle a gooseneck. |
 | The problem presented to you is not the weight capacity, but more likely the clearances required for your trailer. Most fifth wheel trailers are RVs with a wide nose which can interfere with the cab of the truck when turning. Most gooseneck horse trailers have a tapered nose which allows for tighter turning radius without hitting the cab. Contact an experienced hitch manufacturer like B&W and see what they say. They make a hitch that slides back when needed for maneuvering and forward for transporting. They also make an offset gooseneck. Nice people to deal with. |
 | try this: http://www.turnoverball.com/category/vehicle/ford/2014/f150 |
