| I might sound a bit like a commercial for this product but I had to share, as you can see I have well over 400 posts. I'm not new here just trying to sell a product...I have zero affiliation with the company.When I bought my trailer a few years ago the pipe on the grey water tank was almost completely broken off and the black water tank was leaking. Over the years I tried a lot of fixes, more than I can even remember. Some kind of worked, some worked for a while, some didn't work at all. I thought about replacing but my trailer is a 2002 and I couldn't find an exact match for the tank. There are lots of regulation regarding the work on a black water tank so it was going to be expensive for someone else to do. I didn't know if I wanted to do it myself.A few weeks ago I decided to try Plasti-mend after reading a post on an RV forum and I have to say it works as advertised. I feel like my tanks are fixed for good, I have no more leaks and the repair is awesome. Like I said this might sound like a commercial but my intent is to share in case anyone else is in a similar position and can't find a fix. http://www.amazon.com/Plasti-Mend-Plastic-Repair-Holding-Tank/dp/B0... |
   Location: Pleasant Plain, Ohio 45162 | Thanks for sharing - made a note of it in case!!!! |
    Location: Rayne, LA | I used the same ( or very similar )product a few years ago and it held up for several years then I sold the trailer. Probably still holding, I was happy with it also. |
    Location: MS | Thank you for sharing this and your result, because you just never know! |
  Location: Pueblo, CO | I ordered this to see if I can fix a tank that has been leaking for too long! I hope it is the answer I need! |
| Originally written by paysonw on 2014-06-23 4:22 PM
I ordered this to see if I can fix a tank that has been leaking for too long! I hope it is the answer I need! It is still holding for me...I hope it works as well for you. |
