Gooseneck - truck clearance
Tim & Time
Reg. Aug 2011
Posted 2014-05-20 9:09 PM (#159148)
Subject: Gooseneck - truck clearance
Have done a couple searches with not much luck so not sure if I am asking right. Is there a rule of thumb or a standard for gooseneck height/clearance over a standard pickup box? Or does it go by trailer level, a  combination of both or ??? Thanks Tim
kooner
Reg. Jun 2011
Posted 2014-05-20 9:23 PM (#159149 - in reply to #159148)
Subject: RE: Gooseneck - truck clearance
start with trailer loaded and level, on the new trucks if you have over 6" your lucky both of my Dodges have a little less than that and I have no problems but I do watch for big dips and you do have to be watchful. Only other thing you can do is have a flat bed or block the axels for more clearance.
Tim & Time
Reg. Aug 2011
Posted 2014-05-20 9:33 PM (#159150 - in reply to #159148)
KOONER,  Thanks I am working with a 2006 dodge extended cab long box 4X4 and a 2004 Sundowner not new to trailers but am new to goosenecks and trying to figure out where I need to be. Tim
Posted 2014-05-20 10:50 PM (#159152 - in reply to #159148)
If all else fails put a deck on truck...:) http://www.hillsboroindustries.com/Products/AluminumTruckbeds.aspx
