   Location: MD | I have a 30 gal under gooseneck water tank that serves well for human needs. However, I've been carrying four 5gal buckets in the rear tack area for horses and takes up too much room. I measured for one of those triangular stand tanks, but only have just under 14" to the tack pole. The 39gal water caddy is 14 on sides, 14.5 across. I don't want to pay $50 shipping and then $50 back if it doesn't fit like I'm thinking it won't. The under trailer joists are 12"W x 4"D but don't see anything that size.
I really want to keep it on or behind the axles. Does anybody have any "out of the box" suggestions besides the roof? Garage door height prohibits roof adds over 11". |
      Location: Rocky Mount N.C. | I use these in the 7 gallon size, put them where I want and use as many as I want.... https://www.relianceproducts.com/products/hydration/79.html You can pick them up at Walmart, Amazon, REI, etc...
Edited by retento 2014-05-05 11:09 AM
| On the water tank question, is it better to put a 45 gallon tank on my hay rack or in my pick up bed. I noticed you said over the axels........? |
   Location: MD | Originally written by Daisey on 2014-05-05 2:14 PM
I already have a 30 gal (240 pounds) under the GN nose and don't want to put 40 more gals (400 pounds) in front of the axles which would add pin weight. Don't know what your truck payload situation is, but I'm looking to keep it on the axles or behind them.
    Location: Texas | Originally written by RidnClyde on 2014-05-05 9:17 AM
I have a 30 gal under gooseneck water tank that serves well for human needs. However, I've been carrying four 5gal buckets in the rear tack area for horses and takes up too much room. I measured for one of those triangular stand tanks, but only have just under 14" to the tack pole. The 39gal water caddy is 14 on sides, 14.5 across. I don't want to pay $50 shipping and then $50 back if it doesn't fit like I'm thinking it won't. The under trailer joists are 12"W x 4"D but don't see anything that size.I really want to keep it on or behind the axles. Does anybody have any "out of the box" suggestions besides the roof? Garage door height prohibits roof adds over 11". Yes it will fit. If you don't believe it, cut out a piece of cardboard with the tank dimensions and try it. |
