Tack door hinges
gemm
Reg. Feb 2005
Posted 2014-04-30 12:13 PM (#158868)
Subject: Tack door hinges
100100100100252525
My 1992 Featherlite tack door is gradually drooping. It looks like there are some white washer-like things where the pin goes. They're chipping out and now the hinge is metal-on-metal. I have to really slam the door to get it to close, as it scrapes along the bottom of the trailer frame. Can I just replace the washers w/o replacing the whole hinge? Our local RV repair place wants to replace all the hinges. New hinges aren't expensive, but I'd rather not unscrew the existing hinges on this older trailer if it's not necessary.
horsin around
Reg. Jun 2005
Posted 2014-05-02 2:22 PM (#158911 - in reply to #158868)
Subject: RE: Tack door hinges
100100100
A little different but sounds similar, I had a hinge drooping on one of my center dividers in my trailer. I have a stud wall on it and it drooped enough and wore enough that you had to lift up the divider to open it. It was too heavy for me to lift the divider and pin to open at the same time so I was going to have the hinge replaced. They guy I was going to have to do it suggested I put in some washers in. I found something similar to a washer but thicker like a bolt and it lifted it up just enough that it worked perfect for me after that.It's be worth trying to replace the washers first to see if it helps.
beeoerdog
Reg. Jan 2014
Posted 2014-05-02 2:37 PM (#158912 - in reply to #158868)
10010010010025
Those white things are probably just bushings and should be available from Featherlight or your RV store
