Took Frig Out- said wiring was corroded?
walkin
Posted 2014-01-30 12:58 PM (#157250)
Subject: Took Frig Out- said wiring was corroded?
500100
That's 3 months after they serviced it, and one week after they it was the thermocouple ?If they wires were indeed corroded, would it still work on electricity?I'm worried I'm getting ripped off.Thanks!
Posted 2014-01-31 9:59 PM (#157268 - in reply to #157250)
Subject: RE: Took Frig Out- said wiring was corroded?
Can't tell you without pictures.  Generally, corroded wires can be replaced or cleaned.  Done it many times.
Posted 2014-01-31 10:15 PM (#157269 - in reply to #157250)
Corroded wires can interrupt the proper operation of many types of electrical devices. Fortunately in many cases, the fix can be made with the cleaning of the wiring or terminals, without having to replace the affected electrical unit. After the junctions are cleaned and reassembled, adding a dielectric grease to the terminals will greatly reduce the problem from reoccurring.
