Location: Morriston | I have a 2003 C & C 4 horse slant load with 12' living quarters. Does anyone know where the 12 volt inverter is located on this trailer? The batteries continually boil over and my manual says there is an option you can purchase to regulate the charge into the batteries from the inverter. But I can't find the inverter and C & C is no longer in business to call them for the location. |
 Location: Grayson Co. Texas | The charger/converter is usually on the bottom of the breaker/fuse box....In a outlaw anyway...ask me how I know .................I just replaced mine today.....good luck |
Location: Morriston | Thank you. I'll pull the breaker box and see if it is in that area. I don't know if the C & C trailer will have it in the same place as the outlaw but will find out. |
     Location: Tenn/Ala. | C&C only built the actual trailer shell. There was another company that handled the interior, and if you look around in the cabinets there is typically a data plate with the appliances, capacities, and other builder information listed (usually inside a cabinet door). The actual builder of the coach would be listed there, so you may be able to contact them directly.
Or as has been mentioned, many manufacturers use an all-in-one power center that handles the 110V breakers, 12v fuses, and the converter all in one nice package. On many of these you can get a replacement converter from most any RV dealership as long as you have the make/model info. |
Location: Morriston | That's good info. Showtime did the conversion and they are also out of business. I'm going to pull the breaker box first chance I get and see if the inverter is there. Thanks for the information. |
