  Location: Ohio | I have a newer goose neck horse trailer that has zerk fittings on the hubs. I know this is to push grease into the hub and reduce the need for repacking. I have not packed these types of set ups before. One youtube video on them says to just hook up a grease gun and spin the tires while you pump grease into the hub until it comes out clean. This seems to me to put a lot of pressure on the hub and could eventually blow out the seal. Can you "repack" this way safely on these new trailers or should you still break down the hub every two years or so and do a complete repack manually? Also, since I have not done this in a while, do you all have a particular grease you like. Looking at the red lithium type.
Thanks for the help. Did a search on the site and didn't find anything helpful.
  Location: Zionsville, Indiana | Most of the new trailers we sell have Dexter "EZ Lube" or other brand axles with grase zerks. We always advise our customers to avoid using them and to have their bearings hand packed, preferably once a year. Many people adhere to the theory that if one pump is good, 10 pumps is much better. The EZ Lube system is reallly job security for us as we do make a living in our shop replacing hubs, axle beams, bearings, brake assemblies, etc. When there is not enough grease, obviously the bearings are eventually destroyed, with additional expensive consequences. When there is too much grease, the pressure can cause the seal to leak. The result of that is not only loss of grease in the bearings, but we have had trailers come in that had the brake assemblies packed solid with grease. Usuallly, the trailers were brought in because the brakes didn't seem to be working. Wonder why. At that point it is more economical to replace the entire assembly than to pay for the time it takes to clean the grease out and wait for the shoes to crumble. |
  Location: Ohio | Thanks for the feed back. Seems to support my theory that by using the zerks to "repack" the bearings puts too much pressure on the seals. I will just take them down and repack by hand. I am also buying an old Merhow bumper pull that we found. It has sat for several years and I am sure needs the bearings repacked. Will be a grease weekend.
On another note, what are your thoughts on Royal Purple Ultra Performance grease for the repack? |
  Location: Zionsville, Indiana | No opinions on the grease. (That's something for me - no opinions). We use Kendall Blue, have for many years, no problems or complaints. Everyone in this industry who does the type of work we do will have a suggestions, I am sure. |
    Location: Topeka Ks | Royal Purple UPG is good grease. I haven't seen too many spec sheets that can beat it. I hope you are inside..Jg On another note, what are your thoughts on Royal Purple Ultra Performance grease for the repack? |
       Location: western PA | If you are repacking the bearings every year and you aren't pulling in very wet conditions, or long, high speed, hot trips, any petroleum based wheel bearing grease will do the job. If you want to extend the repacking schedules and have very wet conditions such as boat trailer immersions, synthetic grease of various brands is the ticket. It won't wash off like the dino grease and won't be contaminated by the water. The bearings will run cooler and longer with the synthetic greases. |
  Location: Ohio | The new (to us) Merhow will not be pulled on long trips. It will be used for day trips and going to the vet. It is a two horse bumper pull. The big three horse LQ goose neck is used for the longer hauls. We usually go to MI from Dayton OH 4-5 times a summer with it and those are 7-8 hour trips. I think it will be easier to do the lithium in both rather than a different grease in each. The little trailer would not be in water/rain much but the big trailer will be hauling in it occasionally. I would rather extend the life of the bearings and have them run cooler.
Thanks for the help. |
      Location: Missouri | First trailer I owned with these was a 98 4-Star. I jacked the wheels up and used the grease zerk every other year for 12 years. Never had an inner seal fail, never had a bearing issue. I would rotate the wheel while pumping until new grease came out. |
