Question for user: Poco 5, re: trailer brake issue from 2006..
truckdriver460
Reg. Sep 2011
Posted 2013-11-19 12:55 PM (#155869)
Subject: Question for user: Poco 5, re: trailer brake issue from 2006..
You once posted you had issues with your brakes on the truck/trailer combo surging violently.  Did you ever find out the cause?  I have the same issue and am seeking help.  Doesn't happen all the time.  Electric over Hydraulic brakes.
justgurn
Reg. Oct 2010
Posted 2013-11-19 2:58 PM (#155870 - in reply to #155869)
Subject: RE: Question for user: Poco 5, re: trailer brake issue from 2006..
Do you know what the brand the electric over hydraulic unit you have? What brake controller in in your truck? I'm running the Titan Brakerite and have troubleshooted before.jg
truckdriver460
Reg. Sep 2011
Posted 2013-11-19 3:08 PM (#155871 - in reply to #155870)
seem to recall Carolyse??  Can check when I get home...along with break unit.  Since the brake unit seems to work most of the time, I assume it's compatible.
truckdriver460
Reg. Sep 2011
Posted 2013-11-19 3:10 PM (#155873 - in reply to #155871)
I've been pushed through intersections going 10 mph...the jerking/serging doesn't allow me to stop at all (but only once in awhile).  I go slow because I don't trust it!  It almost feels like anti-lock brakes.  Had electric brakes before and NEVER a problem..so it has to do with the trailer and not the truck.
mulerider01
Reg. Aug 2012
Posted 2013-11-19 5:28 PM (#155875 - in reply to #155869)
I have electric over hydraulic (ausco) with primus controller,2002 hart full lq with a 2005 gmc 8.1 liter and love it ,total weight with 2 head ,with my wife having half the house in it is 21,920
justgurn
Reg. Oct 2010
Posted 2013-11-19 10:55 PM (#155877 - in reply to #155869)
From my research the brake unit works or not. Erratic brakes is likely a bad connection or faulty wire.You can test the unit by pulling the emergency disconnect and then go listen to the unit. It should be running continuous and the pump should be humming. BTW this is the same way to bleed the brakes.
mulerider01
Reg. Aug 2012
Posted 2013-11-20 1:26 PM (#155888 - in reply to #155869)
Just ,great hint on bleeding them brakes......Thanks
justgurn
Reg. Oct 2010
Posted 2013-11-20 1:29 PM (#155889 - in reply to #155869)
FYI: When bleeding the brakes using this method be sure to refill the master cylinder reservoir after every wheel. It empties very fast. jg
