Winterizing and refrigerator on or off?
d2allen
Reg. Jan 2011
Posted 2013-10-14 12:01 PM (#155348)
Subject: Winterizing and refrigerator on or off?
Getting ready to winterize my l.q. trailer and put it into storage (plugged in with a battery tender). Is it better to leave the empty fridge running or should I turn it off?
cajunmuleman
Reg. Oct 2011
Posted 2013-10-14 12:56 PM (#155349 - in reply to #155348)
Subject: RE: Winterizing and refrigerator on or off?
My suggestion would be turn off and leave door open
trot-on
Reg. Dec 2009
Posted 2013-10-14 5:01 PM (#155351 - in reply to #155348)
I turn mine off between trips and take out the perishable food. But friends leave their plugged in and running between trips. What is more common?
cajunmuleman
Reg. Oct 2011
Posted 2013-10-14 5:35 PM (#155353 - in reply to #155348)
I also leave mine running between trips but if storing for an extended period I would turn it off. We ride pretty much year round, but I was raised with a family that did camp periodically thru the year and would always turn it off between trips.
Arieldouglas
Reg. Aug 2013
Posted 2013-10-14 7:32 PM (#155354 - in reply to #155348)
I keep mine on year round. But it usually has some adult beverages in it even when sitting in the barn.
Posted 2013-10-15 9:00 AM (#155362 - in reply to #155348)
If you have no plans to use the fridge over the winter, turn it off and open the doors. It's a mechanical unit, subject to wear and expensive repairs. Why subject it to years of unnecessary wear for no reason? One winter's continuous operation, would probably exceed the wear of several summer's partial usage. As well, it will cost unnecessary money to keep it running.
d2allen
Reg. Jan 2011
Posted 2013-10-15 4:48 PM (#155368 - in reply to #155348)
Thanks for all the replies. I was looking for an answer with a mechanical reason behind it and I think Gard nailed it. In the back of my mind I wondered if the compressor was better left on....but decided to turn it off for the winter.
cajunmuleman
Reg. Oct 2011
Posted 2013-10-15 5:51 PM (#155371 - in reply to #155348)
Actually doesn't have a compressor. It works off a pilot flame and a heating element that causes the gas to move within the system that transfers heat and makes things cold.
Posted 2013-10-15 10:43 PM (#155374 - in reply to #155371)
During an extended storage, running the fridge on gas would be expensive, and instead, the electrical heater would probably be utilised. This would involve running the converter through the LQ's electrical system as well.
Arieldouglas
Reg. Aug 2013
Posted 2013-10-16 5:03 AM (#155380 - in reply to #155348)
Looks like the further north you are, the more likely you would be to turn it off. After the first frost we drain all the water and blow the lines out but we are subject to ride year round. So, we keep the fridge running.
CYA Ranch
Reg. Feb 2009
Posted 2013-10-16 2:49 PM (#155386 - in reply to #155348)
I live in the frozen tundra of South Dakota. My fridge gets turned off when I winterize. I clean it extremely well and shut the door. If I leave it open I forget about it when I pull the trailer and it would probably break something banging around. I've done this since the trailer was new in 06. I also keep my trailer plugged in all winter to trickle charge the batteries. I turn it back on in the spring before my first trip and leave it run for the season.
