  Location: Knoxville | I have my trailer in having a bunch of work done, and they have determined that the cooling unit in the fridge is broken. I don't think it's worth $700 or so to replace that tiny fridge. Any thoughts on where to get an electric only that will fit in that spot? Or a pre-built cabinet to fit there? |
       Location: Northern Utah | If I read your post correctly, you are saying that you don't care about a 12volt or propane features of a fridge and only want a 110v system. If that is the case, I would just check with any of the appliance stores for a small under counter fridge. Nothing is going to fit exactly the spot you have, So it is just a matter of finding something that is close in size. Any cabinet shop should be able to build you a cabinet that will fit into the empty space if you just want storage. |
  Location: Knoxville | I'm a dummy - so 12 volt would run it while it's on the battery power? I guess it's the propane part I don't really care about. If we're camping without power, I'll manage with just a cooler. If an electric only fridge won't fit, I'll just always manage with a cooler, lol. It's so small, it's not really worth a lot to preserve the space as a fridge if it's going to cost hundreds of dollars. |
       Location: Northern Utah | Most RV fridges come in either 2 way or 3 way. Meaning they will run on two or three sources of power. 110volt, 12 volt or propane. |
    Location: MS | I took my 3 way Norcold out, too. Put in a bigger all electric that I got for $75 off Craigslist, brand new still in the box. I did have to adjust the cabinet, but I think this will be a better solution for me. |
  Location: Knoxville | That's what I'm thinking. The Norcold is so tiny; it doesn't hold much at all. If I'm going to have to spend some money, I'd rather have something more useful. |
