torsion axles
tbolt
Reg. Aug 2013
Posted 2013-08-27 2:49 PM (#154337)
Subject: torsion axles
I lost all the tread on the center of my right front tire. When I changed the tire I noticed that the space between the tires on the left was 1 and 1/2 inches colcer then the right side.
Posted 2013-08-27 2:57 PM (#154339 - in reply to #154337)
Subject: RE: torsion axles
Originally written by tbolt on 2013-08-27 2:49 PM
Have you hit a curb or big pothole recently?
Spin Doctor
Reg. Nov 2008
Posted 2013-08-27 3:19 PM (#154340 - in reply to #154339)
Was this while trailer was on the jack? Or did you use a block?
If you take the load off or overload the torsion, it will change the caster/camber of the tire in relationship to the trailer frame and that possible is what you are seeing?
If this is while weight is equal on all tires, oops, you have a problem....good luck!
